What series carrier do I have?
Old Sep 14, 2003 | 02:27 PM
JONEZ_Z's Avatar
Im going to get some 3.73s and they want to know what carrier i have. Also, should i go with motive gears or strange? Is the install hard to do or should i pay a pro? Thanks guys.
Old Sep 14, 2003 | 02:29 PM
BigEvil's Avatar
Depends on your stock gear ratio. 3.42, you have a 3 series carrier.
Old Sep 14, 2003 | 02:36 PM
ibanez6rg's Avatar
You have 3.42s stock so you have a 3 series carrier.
Old Sep 14, 2003 | 02:43 PM
JONEZ_Z's Avatar
So have either of you guys done a gear swap yourself? Im deciding if im gunna do it myself of not.
Old Sep 14, 2003 | 05:22 PM
BigEvil's Avatar
Just ordered my gears this morning, so no not yet.
Old Sep 14, 2003 | 06:40 PM
robb4964's Avatar
Jonez , if I was you I would not do it my self . You need a press to do it right , the pinion is going to have to be pressed many times to get set right and the carrirer is going to have to come out many times until thje gear pattern looks right . Otherwise you may end up messing up your rear end , very badly . I have a friend that put them in his self , He is a mechanic , and a prety good one . He messed up a lil and it ruined his new carrier and hjis gears . Its worth a few hundred dollars to let the pro's do it . I just put 4:10's in mine actualy i watched and my buddie " recertified tech " did it , good luck!!!
Quickss96
Jan 29, 2016 05:56 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Catmaigne
Jul 14, 2015 05:17 PM
Dr. Weir
Aug 2, 2002 02:36 AM
CW 99 Z
Jun 23, 2002 08:30 PM
