What scanner do you use to pull codes?
Old Dec 26, 2006 | 07:12 PM
gripex's Avatar
i want to buy a scanner for my setup, which one to get? i dont wanna mess with the cables and laptops etc. I just want a 16 pin scanner that does obd1.5 stuff for my 1995 camaro, anyone got any brands or links? thanks
apparently its 16 pin, but obd1.5 or or obd1 which scanner will work?
Old Dec 26, 2006 | 08:17 PM
billk1's Avatar
jut picked one up from autozone, actron very basic, with cable for obd1 for about 270- 30 for rebate
Old Dec 26, 2006 | 08:45 PM
OBE1 95Z28's Avatar
The 1995 Camaro is OBDI, but the connect is the OBDII style. No such thing as OBD1.5
Old Dec 26, 2006 | 08:56 PM
moparman's Avatar
Autoxray.
Old Dec 26, 2006 | 09:22 PM
If the OBD-I scanner you get doesn't have the adapter for the 16-pin ALDL connector, Shoebox has the info you need to jumper to a 12-pin OBD-I connector:
http://shbox.com/1/xraycable.jpg
lt1matt
Mar 21, 2015 07:35 PM
aj2494
Mar 12, 2015 10:17 PM
Gtpguy
Jan 26, 2015 04:50 PM
91Bird305
Aug 5, 2002 01:39 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
