What rockers will clear head studs?
Old Nov 20, 2004 | 02:58 PM
Mullet Z28's Avatar
I just noticed that the wide-body rockers I have are hitting the center row of head studs. There generic non-centerbolt-style, non-self aligning Summit cheapo rockers.
I take it I need a more narrow body rocker. So people running head studs, what rockers do you have?
Old Nov 21, 2004 | 04:24 PM
Mullet Z28's Avatar
Re: What rockers will clear head studs?
Maybe just any narrow-body rockers will work? I need them to clear 1.55" springs.
Old Nov 21, 2004 | 05:51 PM
Red_94Formula's Avatar
Comp cams full roller steel rockers are the way to go. Coslty though.
Old Nov 22, 2004 | 09:56 AM
IROCET's Avatar
Crane Cams Gold Race rockers are specifically designed for centerbolt valve covers. They come in 1.5 and 1.6 ratios both self-aligning and non self-aligning. At www.summitracing.com they list for $319.95 or at www.jegs.com for 309.99. According to Jeg's, these are the only aluminum rockers available for GM self-aligning applications. And they are supposedly the same rockers used in the LT4 (again according to Jeg's).
Matt
Old Nov 22, 2004 | 10:20 AM
trans9_5am's Avatar
Not sure if this will apply to your rockers or not but you may be able to modify the valve covers like you do when installing CC pro mag 1.6's. Here is a guide to modifying the stock valve covers:
http://www.hotss.com/Members/scott_vaca/pro-mag.htm
You can always try this to see if it works. It will not hurt the valve covers.
Brandon
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
95chwagon
Jan 13, 2015 09:19 PM
Catmaigne
Dec 25, 2014 12:16 PM
