What is the purpose of the WP weep hole?
Old Nov 28, 2004 | 01:32 PM
chevroletfreak's Avatar
What is the purpose of the water pump weep hole? I just started leeking today.
Old Nov 28, 2004 | 01:58 PM
magnumv8's Avatar
Re: What is the purpose of the WP weep hole?
It lets you know that your seals are bad, and you need to replace the waterpump.
Get it fixed right away, or you will be changing your opti as well
Old Nov 28, 2004 | 02:31 PM
MentalCaseOne's Avatar
TO TAKE OUT THE OPTY SPARK!!!
See the Engineers figured... why do a half assed job and not replace a high mileage opty at the same time?
No I really dont know but...interesting question.
Marvin
Old Nov 28, 2004 | 04:04 PM
RedRebel's Avatar
It lets you know the seal is bad and its leaking.
Old Nov 28, 2004 | 04:54 PM
marshall93z's Avatar
is there a way to fix this tourself...instead of buying a damn new WP??
Old Nov 28, 2004 | 06:37 PM
tonylittell's Avatar
**** man there is a guy selling a brand new water pump in here for 50 bux....buy his ...be a whole lot better off then trying to rebuild yours....i was gonna buy it myself,but it sounds like you need it worse than i do...i was just gonna get it as a spare because of how cheap it is
Old Nov 28, 2004 | 09:08 PM
94ta383's Avatar
No. The weep hole is there to let you know the pump is bad. Replace it. Waterpumps are cheap.
Do the Opti while you're in there if you can afford it.
Old Nov 28, 2004 | 09:20 PM
What else would be "a good idea" to replace? It is a 93 and I am now at 130,000 miles.
Thanks for the help.
Old Nov 28, 2004 | 09:36 PM
ejfagala's Avatar
Talking Re: What is the purpose of the WP weep hole?
That is probably closer to the truth then we want to know, ever wounder why retail on an Opti from GM was so much $$$$$$$$$$$$$$?
Old Nov 28, 2004 | 09:41 PM
meengreen 94z's Avatar
Yeah the waterpump has two seals on the shaft. When the first one lets go it drips out the weep hole. If it werent there and the second seal went bad it would squirt out the shaft at a far greater rate.
Some lazy people weld/seal the weep hole shut when they start leaking, but thats not a smart idea considering at somepoint the other seal will go bad as well.
Old Nov 28, 2004 | 10:08 PM
Dave88LX's Avatar
Throw in an Electric Waterpump while you're at it.
G-BODYT56
Jan 14, 2022 11:14 PM
drt
Sep 27, 2015 04:39 PM
generaldave
Sep 25, 2015 06:48 PM
4586
Jul 31, 2015 06:03 PM
Boss002
Jul 24, 2015 10:47 AM
