WHAt is the proper way to put trans am stands
Old Feb 4, 2005 | 01:05 PM
gtkilr95's Avatar
I need to lift my car on to jack stands. What is the proper way to do it. Do you put the front then the rear or do you do it side to side?
Old Feb 4, 2005 | 01:42 PM
slverbullet's Avatar
Re: WHAt is the proper way to put trans am stands
It probably really depends on what it is your trying to accomplish. This is probably an obvious answer. So I would only assume that you needed the whole car in the air. I dont know that I would have a set procedure for doing so. Just make sure that when you lift the front or the back, keep the opposite end tires chocked. I usually lift the front then to the back. If I lift from one side then do the other, I find it difficult to get my jack under the vehicle (i have a TA with stock side ground effects) and I would worry about it sliding a bit toward me (it would only be a slight amount but to each their own). Only my thoughts on the matter.
DirtyDaveW
Dec 1, 2016 05:37 PM
Sergio
Jan 27, 2016 04:27 PM
PCLZ28
Dec 24, 2015 05:19 PM
jb4xx
Feb 2, 2015 10:00 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
