what problems will a bad map sensaor cause?
Old Jul 13, 2004 | 08:13 PM
MattysTA's Avatar
just wondering cause im getting two codes for it. p1107 and p0107.
also what problems can you get from a blown collector gasket besides that side running lean? thanks in advance guys.......
Old Jul 13, 2004 | 09:50 PM
n2ceptor's Avatar
MAP Sensor (Manifold Absolute Pressure) Measures the air pressure in the intake manifold. Changes in engine operation and speed will affect the MAP sensor reading, which the computer uses in fuel and timing calculations.
Dont know about the Collector gasket...
Old Jul 13, 2004 | 10:29 PM
lastze4me's Avatar
I had a MAP sensor go bad a couple of years ago.....My car stalled as I slowed down at stop lights and when ever I gave it a little gas, it would stall. Under full throttle it was fine. Dealer wanted to :
1) Replace exhaust manifolds for $850(symptoms were as if the exhaust had a leak).
2) Replace CAT
3) just plain out bend me over backwards!!
Old Jul 14, 2004 | 07:42 AM
It probably won't run very well with a true MAP problem. Check the wiring and the connector first. A scan tool would be helpful, as well.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
Fatdog2
Feb 13, 2015 08:19 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
Amshnock
14
Jan 18, 2015 11:47 AM
