What plug wires are you running?
Old Jan 4, 2007 | 10:11 PM
  #16
Originally Posted by 97s10ondubs
What setup is that, i like
Opti optical sensor feeding MoTeC M48Pro engine management system, MoTeC IEX 8-channel ignition driver running 8 LS1-style coils. You could do the same thing with the Bailey Engineering LTCC.
Old Jan 4, 2007 | 10:24 PM
  #17
mdacton's Avatar
I got the sumit ones
Had the MSD....kept burning number 7
Old Jan 4, 2007 | 11:37 PM
  #18
94slpz28's Avatar
I ran the Accel 9000 race wire...loved them
Old Jan 5, 2007 | 01:12 AM
  #19
Z-RATED94's Avatar
Taylor OTVC. They were over the top for a few weeks but when the car went into the shop to swap the shorties for longtubes they decided to run them in the stock locations. Oh well.
Old Jan 5, 2007 | 01:14 AM
  #20
KWIK WS6's Avatar
From: Southern California, where do YOU live mutha****a?
MSD's factory route
Old Jan 5, 2007 | 01:53 AM
  #21
SS RRR's Avatar
Originally Posted by Injuneer
MSD 8.5mm, cut to fit, routed under the headers, from 8 LS1 coils on the lower radiator support.
http://www.injuneer.com/images/photos/Engine/CoilsR.jpg
HOLY COW THERE'S DIRT ON THE UNDERSIDE!
Old Jan 23, 2007 | 08:45 PM
  #22
FASTFATBOY's Avatar
Will 8mm wires fit behind the acc bracket?
David
Old Jan 23, 2007 | 11:57 PM
  #23
tireburnin's Avatar
The 8.5 MSDs were a tight fit for me. They did clear the bracket though.
I ended up cuting a wire when a serpentine belt jumped off due to the wierd routing. Take care to secure the wires. The tight fit left one or two wires sticking out a bit right near my AC bracket.
Old Jan 24, 2007 | 12:06 AM
  #24
formula-bird's Avatar
Taylor's factory route with pasesetter LT's
Old Jan 24, 2007 | 07:40 AM
  #25
IXLR894Z28's Avatar
Crane firewire FWIW.
Old Jan 24, 2007 | 01:30 PM
  #26
hotrod18_69's Avatar
Accel 8.8 300+ Race Wire.. Can't complain, works great with my Delteq setup!
Old Jan 24, 2007 | 05:30 PM
  #27
Guest47904's Avatar
Guest
0 ohms of resistance
Granatelli wires in stock location. 0, that's zero ohms of resistance. Hooker headers (they're the worst) Get everything I can from Summit. I think they were 160.
Got some MSD wires you can buy cheap from me. Never used
Old Jan 25, 2007 | 09:21 AM
  #28
bdc95ta's Avatar
Magnacore: roughly $100 custom length for LTCC
TPIS LT's
Old Jan 25, 2007 | 09:30 AM
  #29
FASTFATBOY's Avatar
WHat color, size, what boots, cut to fit or pre-made.
David
Old Jan 25, 2007 | 02:53 PM
  #30
Guest47904's Avatar
Guest
David
They are cut to fit. Correct boots for opti and plug ends. Like stock. Coil wire is too long. Just looped and wire tied it. They are Blue.
See them here.
http://www.granatellimotorsports.com...kplugwires.htm
Funny but I thought the "0" ohms would get someones attention.
Since they provide so much energy, you can (they even come with instructions) to open the gap a little more for improved performance.
