What other valvetrain upgrades needed with cc503 cam swap
Old 03-13-2007, 04:30 PM
  #16
reamo04's Avatar
how many miles on the stock lifters?
u might be able to get by with the stock timing chain, im not entirely sure. im not entirely sure if those come with 1.5 RRs, or 1.6's, someone else should be able to clear that up.
I would look into hardened pushrods too while your in there.
reamo04 is offline
Old 03-13-2007, 05:09 PM
  #17
Kain's Avatar
I can tell you from experience, do not try to skimp on parts when dealing with your valve train. Spend the money and get it done right the first time.
Get Crane/Comp Cams lifters or something more serious for a big cam, chro-mo push rods, make sure you've got the right valve springs, make sure they're set with the right number of shims, 7/16th rocker studs, 7/16th stud non-self-aligning roller rockers, gm guide plates, gm heavy duty timing chain, ect.
Kain is offline
  #18
BradcTA's Avatar
107K on the stock lifter. I'm definately getting new lifters, I'm just asking if OEM are OK. The kit comes wiht 1.6 rr.
BradcTA is offline
Old 03-13-2007, 05:38 PM
  #19
Z95m6's Avatar
I disagree on the lifters. If you remove the stockers and they look fine I'd run the stockers. I'd take used stock lifters over skimping and running a stock chain or stock chain replacement.
Z95m6 is offline
Old 03-13-2007, 05:44 PM
  #20
BradcTA's Avatar
Shouldn't you always replace the lifters when doing a cam swap?
So far I have:
cc503 cam
lifters
timing chain
springs
bolts
1.6rr are like $250. Do I really need those. I'm trying to cut out parts I don't have to have.
BradcTA is offline
Old 03-13-2007, 05:49 PM
  #21
Colin91Z's Avatar
Stock rocker arms aren't capable of handling the lift that the cc503 has. Yes, you need roller rockers with a cam like that. Don't skimp here, you'll be sorry.
Colin91Z is offline
  #22
Z95m6's Avatar
So far I have:
cc503 cam
lifters
timing chain
springs
bolts
Replacing lifters isn't a necessity when doing a cam swap on a roller lifter motor. If it was a flat tappet cam you would want to replace the lifters at the time of the cam swap. The same thing with roller rockers, going with a nice used set can save you some dough as well.
Z95m6 is offline
Old 03-13-2007, 06:52 PM
  #23
Dave1980's Avatar
I ran them for a few months, before getting my 1.6 Crane Golds. Also running my stock lifters with my cam.
Dave1980 is offline
Old 03-13-2007, 07:39 PM
  #24
AmericanMuscle33's Avatar
Unless you're deadset on that cam, or already purchased it I'd say consider the hot cam kit like previously stated.
You can get the Cam, 1.6 roller rockers, valve springs, valve caps, valve keys, valve spring shims, for $536.54 from...*cough* GMPartsDirect *cough*
This way everythings GM quality, and engineered to work together. Get an upgraded timing set, don't run OEM. People have already listed cloyes, LT4 Heavy Duty set....I'd personally recommend a LUNATI HD set if you're budget minded. I've seen them for as cheap as $180.00 new from JEGS, and you can run the stock timing chain cover if you have a non-vented opti with this timing set (which you cannot do with a double-roller setup). Then get Chrome Moly purshrods. This will compliment everything else, and you should be able to find a name brand (CRANE, etc.) new set for around $50.00 if you hunt around. Again like previously stated, inspect you're stock lifters, if they look good run them. If you're skeptical I'd get OEM replacements, you can get 'em for $26.00/8 from GMPartsDirect.
So:
LT4 Hotcam Kit - $536.54 P/N # 12480002
Lunati Timing Set - $180.00
Chrome-Moly Pushrods - $50.00
OEM Lifters (if needed) - $52.00 P/N # 17120735
This comes to $766.54 w/out lifters...$818.54 w/lifters.
This seems to be a realistic alternative considering your budget. Just my $.02.
AmericanMuscle33 is offline
Old 03-13-2007, 08:35 PM
  #25
BradcTA's Avatar
Uh, the lifters are $26/per. Would bring the total to $895 w/s&h. How much better is the cc503 vs. the hotcam anyway?
BradcTA is offline
Old 03-13-2007, 09:12 PM
  #26
Kain's Avatar
Big mistake. I did the same and mine failed.
Kain is offline
Old 03-13-2007, 09:18 PM
  #27
BradcTA's Avatar
The lifters or the chain?
BradcTA is offline
Old 03-13-2007, 09:22 PM
  #28
Kain's Avatar
Lifters, I should have specified.
Kain is offline
Old 03-13-2007, 11:24 PM
  #29
buzz12586's Avatar
The cc503 with stock heads through a M6 should put down 330-340ish. Hotcam puts down 310ish I believe.
buzz12586 is offline
Old 03-14-2007, 03:06 AM
  #30
The lifters are exactly $26.48 per package of 8......so $52.96 before shipping...excuse my 96 cents of error. As far as shpping goes that is arbitrary, dependent on who you buy from, how much you buy, etc. GMPartsDirect can be high on shipping, I'm merely using it as an example. You should be able to find all these parts for what I've listed or cheaper if you are patient and capable of hunting down good deals.
Again, arbitrary...you'll have to be much more specific than that if you want to compare output.
...meh, I gave my opinion on a budget valvetrain build...take it for what it's worth...
Quick Reply: What other valvetrain upgrades needed with cc503 cam swap
