What are the odds of the optispark seal leaking?
Old Nov 7, 2003 | 08:55 PM
Rob94hawk's Avatar
The old optispark seal was somehow permanently stuck to the timing cover so it had to be pried off piece by piece with a razorblade! I tried as best as I could to get everything off but there is some residual pieces left over.
I put the new one on and torqued down the optispark. So what is the chance that it will leak oil?
Do you think I should have put some ATV sealant around the edges or do you think the heat from the engine will mold it around any imperfections?
Thanx, Rob
Old Nov 7, 2003 | 08:59 PM
speed76demon's Avatar
All i know is the shop that put mine in. Didn't use sealant the first time and it leaked so they had to tear it all apart and do it again. But after the sealant it worked fine.
Old Nov 7, 2003 | 09:30 PM
Rob94hawk's Avatar
What type of sealant? I'm sure high temp ATV should do just fine though.
Old Nov 7, 2003 | 10:54 PM
Red_94Formula's Avatar
You mean cuz I did not use any sealent when I put in a new seal is the reason why I keep flooding oil into my optis!!! So exaclty where do I put the sealent around edges of the timing cover where the seal fits into? Then simply press in the new seal.
Old Nov 7, 2003 | 11:56 PM
Rob94hawk's Avatar
Ya know, I was wiggling the waterpump spline shaft and it looked like the seal had shrunk a little. I guess I should expect a leak from there as well.
If I take the timing chain off, it's just going to snowball. With my luck I'll end up tearing the oil pan seal as well...
Old Nov 8, 2003 | 01:15 AM
Robert95z's Avatar
your kidding???? I didnt put any sealent on my optispark seal!!! should i be worried?
Old Nov 8, 2003 | 07:49 AM
OneFlyn95z28's Avatar
As long as you installed it correctly it should be fine. That is unless you cut grooves into the seal surface trying to get old on off.
The red/green 'paint' on the out side of the seal is actually a type of sealant
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Aug 11, 2002 02:24 PM
RobertoZ28
Jun 16, 2002 02:04 PM
