What Octane?
Old Jan 28, 2006 | 04:14 PM
Z28LT1_Just_Nasty's Avatar
What Octane?
Stock F-body LT1, what octane gas is it supossed to run? I never had an owner manual to this thing and I'm just curious.
Old Jan 28, 2006 | 04:18 PM
aarontracy's Avatar
Re: What Octane?
i always run 93
Old Jan 28, 2006 | 04:29 PM
Re: What Octane?
Is that what it says to run from the factory?
Old Jan 28, 2006 | 04:57 PM
MyShibbyZ28's Avatar
Re: What Octane?
Factory owners manual says to run 91 or higher.
Old Jan 28, 2006 | 11:24 PM
Re: What Octane?
You can find links to .pdf copies of the factory Owner's Manual on Shoebox's web page:
http://shbox.com/pdf/manuals.html
Old Jan 29, 2006 | 12:27 AM
Re: What Octane?
Wow, this entire time I've been running 87. Well only 3500 miles worth of driving, the thing is in the shop more then its on the road. How much of an acceleration difference would I notice using 91 vs 87? Oh and btw I have no pinging or knocking using 87.
Old Jan 29, 2006 | 12:30 AM
Re: What Octane?
You aren't going to feel the ping or knocking running 87, there is a knock sensor that retards the timing to prevent that. The accleration is ok from 87 to 91+. Don't think higher octane automatically means more power. You can only get to a certain point and then higher octane does nothing for you.
Old Jan 29, 2006 | 12:33 AM
Re: What Octane?
Oh I know that more octane doesnt mean more power unless you have the tuning to support it. I'm just curious about that 05 Mustang GT I raced, would it have been closer lol
Old Jan 29, 2006 | 12:37 AM
Re: What Octane?
No, it wouldn't have made that much of a difference. The reason people go to higher octane is to get rid of knock retard, which in turn gets the most power possible. If you have knock retard then yes it would help, but not by much.
Old Jan 29, 2006 | 01:14 AM
Jameslt1TA's Avatar
Re: What Octane?
I always ran 85 when i was stock....never could tell the diff between it and 91. Right now though....i run 91 since my motor is build, i would run 93 but 91 is the highest that they carry around here.
l8r
James
Old Jan 29, 2006 | 01:47 AM
Re: What Octane?
NJ has 94, they call it supreme. I guess really its useless, the most any production car is designed to run on is 93. 94 is quite a few cents higher then 94 too.
Old Jan 29, 2006 | 02:12 AM
lt1street's Avatar
Re: What Octane?
If you have the opertunity to use a scanner that with give you data stream you might see the differents. With the knock sensor feeling dentnation you will see timing getting pulled that mean power is suffering, the timing that you might be be losing is not going to be like 20 hp but every little bit counts!!!!
Old Jan 29, 2006 | 06:14 AM
rock1501's Avatar
Re: What Octane?
Old Jan 29, 2006 | 08:34 PM
bstieboydp's Avatar
Re: What Octane?
Originally Posted by rock1501
i second that lol
Old Jan 29, 2006 | 10:53 PM
Re: What Octane?
l8r
James
Not necessarily a problem. If he's in the mountains in Wyoming, his octane requirement will be much lower than it is for those of us at or near sea level.
NJ pumps generally carry 87, 89 and 93. Put a scanner on it. In the winter, with cooler intake air temps, the 89 may be OK. You'll only know if you check for knock retard with a scanner. In the summer, with high ambient temperatures, you will be better off with the 93. As the engine ages, carbon can build up and increase the octane requirement. You can't really generalize, particularly on an engine that's 11 years old.
Aug 24, 2015 06:41 AM
dkred94z
Aug 20, 2015 03:09 PM
kahouna23
V6 Tech
Feb 10, 2003 06:08 AM
frankjr8
Feb 8, 2003 11:03 PM
camaro98_speed
Dec 14, 2002 03:50 PM
