What is Max Valve Lift on Stock Heads?
Old Jul 14, 2003 | 09:48 PM
95Blackhawk's Avatar
Just want to know. Then I can go to the guy who did my heads and see how much he shaved when he cut my spring seats. Also currently have 1.6 rockers.
Is there a way to determine what lift is available in my springs? I am all set up for a cam without the cam and I am getting itchy!
Ben
Old Jul 14, 2003 | 10:28 PM
rskrause's Avatar
Moderator
Re: What is Max Valve Lift on Stock Heads?
Ben
The max lift cannot exceed the distance between the bottom of the retainer and the top of the valve seal. Also, the lift should not exceed the coil bind height of the spring plus ~0.060". If you don't have the spring specs, you can compress them and measure the height.
Rich Krause
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
markaubuchon
3rd Gen / L98 Engine Tech
Jan 14, 2015 01:48 AM
Killer94z
Jan 13, 2015 12:06 PM
Brian-94TA
Jul 31, 2002 02:52 PM
