What is LT1 idle speed....
Old Apr 18, 2006 | 01:59 PM
wrd1972's Avatar
According to the dash tach, what should my LT1 be idling at?
Old Apr 18, 2006 | 02:15 PM
jsetzer's Avatar
Re: What is LT1 idle speed....
M6? Should set right about the 1000 mark on the dash. Maybe a hair below. Its set at 800 rpms, most Z tachs I have seen read @ 200 high.
Old Apr 18, 2006 | 02:22 PM
wrd1972's Avatar
What is the easiest way I can verify "actual RPM". I am trying to calibrate needles which appear to be off.
thanks
Old Apr 18, 2006 | 03:56 PM
DIYAR21's Avatar
well my 97 A4 LT1 idles right on 1000 RPM..
Old Apr 18, 2006 | 04:17 PM
thanks
Hook up a scanner. It will tell you the RPM (to the closest 25rpm increment), based on counting the pulses from the Opti.
Old Apr 18, 2006 | 05:11 PM
chas's Avatar
My 97 Z-28 runs around 750rpms , seems low compared to other people.
Chas
Old Apr 18, 2006 | 05:22 PM
1997blackz28's Avatar
my 97 z idles right at 1000 rpm
Old Apr 18, 2006 | 05:24 PM
birdman1's Avatar
I hate that crap, I had Ion lower mine to 650 when he did the mailorder tune, I like it much better now.
Old Apr 19, 2006 | 07:46 AM
green zr1's Avatar
my 95 z28 idles at about 550 to 600 once it warms up i always thougth it was a little to low compared to others never knew way
Old Apr 19, 2006 | 10:57 AM
The factory PCM programming for an A4 is 550 RPM in gear and 650 RPM in neutral. An A4 that idles at 1,000 RPM has either been reprogrammed or is not operating correctly. Not sure why anyone would even post that information, particularly when the original post is about an M6.
Iamherefornow
Jan 26, 2015 04:57 PM
Gtpguy
Jan 26, 2015 04:50 PM
edman
Jan 22, 2015 02:45 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
smacz28
Aug 6, 2002 01:51 PM
