What Length Pushrods are You Using??
Old Dec 24, 2003 | 01:47 PM
Brandon 95 Z28's Avatar
Question What Length Pushrods are You Using??
Hey,
I am currently having my heads ported, and milled .010, and i will also be running impala head gaskets .029, and am trying ti figure out if I will need to go down to shorter pushrods. Im also running a 306 cam, with 2.00, 1.60 valves. I was orignally planning on getting a pushord length checker, but I dont know if I will have the time to get the heads back, then check the length, and then order and wait for the pushrods, with school starting back up in a few weeks. Is anyone running a similar combo, and what length pushrods are you using?
Thanks,
Brandon
Old Dec 24, 2003 | 02:55 PM
SDAKOVIC's Avatar
Anytime you mill,use different head gaskets do anything to change the deck height you have to check the pushrod length yourself. Every engine is different and even if some body has the same combo the pushrod lenth will probably be different. Dont take a chance at wearing out your valve guides.
Old Dec 24, 2003 | 04:53 PM
rskrause's Avatar
Moderator
Assemble to the motor and get (or borrow) a checking pushrod so that you get the correct length.
Rich Krause
Old Dec 31, 2003 | 04:27 PM
SVT Killer LV's Avatar
You should be cool on stock length. My heads are milled way more than that and I use stock length...
Old Dec 31, 2003 | 05:38 PM
QCKZ28's Avatar
my heads were milled .010, running the impala head gasket, with the combo in my sig, and i used stock length pusrods 7.20"
jesse
Old Dec 31, 2003 | 11:39 PM
rskrause's Avatar
Moderator
Just 'cause people are using the stock length is no reason to follow their lead. It should be measured.
Rich Krause
Old Jan 1, 2004 | 03:52 AM
Rich Krause
Ulitimately this is true.. but he just wanted to get some ideas
13qtr
Oct 28, 2016 08:11 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
realistyc
Jul 28, 2015 07:32 PM
94Form
Jul 17, 2015 10:56 PM
