Cam selection is too hard
Old Dec 30, 2003 | 02:07 PM
1BadBrd's Avatar
Thinking about spring time already i'm wanting a bigger cam then my HOTCAM, which will be for sale this spring.
I talked to Tracey before i left for the Army back in June and he mentioned some numbers. From what i remember i don't see the cam in any catalog. I have been looking at the
230/236 duration, .598"/.608", 112lsa cam from comp cam( alittle big on lift), or
233/240/112/.576/.595 but also need input on the right cam for my heads.
IN EX
200 137.57 115.55
300 190.41 155.80
400 240.57 183.12
450 251.53 193.94
500 259.52 196.86
550 261.45 202.57
Now i don't know the what to look for as far as the head flow and cam slection. When i do the swap i will be having 4.10 put in the rear, it also has a M6.
Old Dec 31, 2003 | 09:14 PM
Josh-'04 GTO's Avatar
Combination Motorsports lists this cam, which would be a great choice for a stick shift NA car with your heads:
TN-230XL 230/236 duration, .544"/.555", 112lsa
Old Jan 1, 2004 | 03:53 AM
SVT Killer LV's Avatar
Just call Combo man... they will set you straight
Old Jan 1, 2004 | 07:40 AM
RE AND CHERYL's Avatar
Cool
I don't think I would go with as much lift as the two cams you've mentioned. It looks like your heads are pretty close to stalling out at .550, and the increase from .500 to .550 is close to nill
Just my opinion
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
armedtrigger
Feb 24, 2015 08:30 PM
Dec 17, 2014 11:00 AM
