What Exhaust Gasket to use with MAC Headers?
The GM aluminum gaskets seem to do well with MACs, at least according to everyone on the board. I've had two sets - the first set blew because I bent the gasket accidentally while installing.
The 2nd set I'm on now has no problems yet..
Originally posted by Dr.Mudge
Fel Pros are more flexible, and I prefer them because of the open ended 2 bolt holes, not that you couldn't cut them yourself if you wanted. I also re-used my Fel Pros without problems.
i've heard the felpro gaskets won't work with mac headers unless certain parts of the gaskets are cut and the bolt holes are enlarged.
Just what i've heard, not too sure how true it is.
Hmm, the bolt holes are a little tight, as for the exaust side they should be larger than what is on the head, so it should not constrict the header. I've never tried the combo though, interestin'.
I want to change my answer here- the Felpros do NOT work right with the MACs. After fixing the lower exhaust leaks, I can now here a huge one at the header to head connection. Going to use GM gaskets now
phantasm99
Aug 28, 2002 11:01 PM
SavageZ28
17
Jul 14, 2002 11:04 PM
