What the heck does this plug go to?
Old May 26, 2009 | 11:36 AM
RealQuick's Avatar
There is a plug that is broken, and has 4 wires (they appear to be pink, brown, purple, and black). one or two may have a stripe on them, but I was just trying to identify the major colors.
It comes off the harness where the starter wires come off of as well (under pass side motor mount). The connector I believe was configured like a square (2 x 2) in stead of 4x1. I can post pics tonight, but what the heck does it go? I do not see the mating piece anywhere?
I can post pics tonight.
Old May 26, 2009 | 11:54 AM
form94's Avatar
Sounds like your talking about the 02 sensor plug. Thats a 4 wire plug but it has tan,blk,purple,and brown.
Old May 26, 2009 | 11:59 AM
RealQuick's Avatar
It could be (a tan wire looks like a dirty pink wire). If I remember correctly though, it was a 2x2 plug, not a 1x4 plug (know what I mean)?
Old May 26, 2009 | 12:27 PM
My Red 93Z-28's Avatar
If it was a 2x2 plug, than it wasn't the O2 plug.
Old May 26, 2009 | 02:43 PM
seawolf06's Avatar
Could it be for the A/C compressor? No. 9 in this pic.
Old May 26, 2009 | 05:01 PM
boosted-lt1's Avatar
I have a non-A/C car and I do not recall a connector like that on that side...
Old May 26, 2009 | 05:07 PM
caldercay's Avatar
Does that mean it *never* had an A/C?
Old May 26, 2009 | 05:14 PM
crash4cyl's Avatar
a/c wiring is usually a 2 wire connector,and flat. all it does is turn the clutch on and off
Old May 26, 2009 | 05:23 PM
Which car are you asking about - the 95 or the 96? The 96 would have a square (2x2) connector for the after-cat O2 sensor, and a flat (1x4) connector for the pre-cat sensor.
Old May 26, 2009 | 05:57 PM
That's correct. It's also a single cat.
Injuneer might be onto something. I believe this is Jon's '96.
-Scott.
Old May 26, 2009 | 10:39 PM
RealQuick's Avatar
I was thinking it might be the post cat O2. here is a pic (96 TA)
Old May 26, 2009 | 10:58 PM
ACE1252's Avatar
Yep....looks like the post cat O2 plug for the driver's cat.
Old May 27, 2009 | 05:26 AM
-Scott.
But a 96 would have dual cats. The single cat cars (93-95) are OBD-I and don't have after-cat O2 sensors or connectors.
Old May 27, 2009 | 06:02 PM
Injuneer,
Somehow I meant that my '95 has neither A/C nor post-cat sensor and I didn't recall ever dealing with that type of connector.
Is that Inductive...or Deductive...either way it was a poor attempt at explaining a thought
-Scott.
Old May 28, 2009 | 05:29 AM
-Scott.
No logic involved.... you posted that its a 96 and had a single cat. Does not compute. Not sure how anyone was supposed to know it was a 95
