What the heck does this plug go to?
There is a plug that is broken, and has 4 wires (they appear to be pink, brown, purple, and black). one or two may have a stripe on them, but I was just trying to identify the major colors.
It comes off the harness where the starter wires come off of as well (under pass side motor mount). The connector I believe was configured like a square (2 x 2) in stead of 4x1. I can post pics tonight, but what the heck does it go? I do not see the mating piece anywhere? I can post pics tonight. |
Sounds like your talking about the 02 sensor plug. Thats a 4 wire plug but it has tan,blk,purple,and brown.
Originally Posted by form94
(Post 5979493)
If it was a 2x2 plug, than it wasn't the O2 plug.
Could it be for the A/C compressor? No. 9 in this pic.
http://shbox.com/1/ac_compressor_mounting.jpg |
Could it be for the A/C compressor? No. 9 in this pic. |
Originally Posted by boosted-lt1
(Post 5979923)
I have a non-A/C car and I do not recall a connector like that on that side...
a/c wiring is usually a 2 wire connector,and flat. all it does is turn the clutch on and off
Which car are you asking about - the 95 or the 96? The 96 would have a square (2x2) connector for the after-cat O2 sensor, and a flat (1x4) connector for the pre-cat sensor.
Does that mean it *never* had an A/C? Injuneer might be onto something. I believe this is Jon's '96. -Scott. |
1 Attachment(s)
Originally Posted by Injuneer
(Post 5979960)
I was thinking it might be the post cat O2. here is a pic (96 TA) Attachment 32966 |
Originally Posted by RealQuick
(Post 5980276)
(Post 5980000)
That's correct. It's also a single cat.
Injuneer,
Somehow I meant that my '95 has neither A/C nor post-cat sensor and I didn't recall ever dealing with that type of connector. Is that Inductive...or Deductive...either way it was a poor attempt at explaining a thought :) -Scott. |
(Post 5980000)
