What goes out inside the opti?
Old Jul 22, 2004 | 08:59 PM
my94blackz's Avatar
Well i tore my opti open this evening and i seen very lil oil inside. The rotor button was green with corrosion along with the points. Is this normal or? What is it that kills it? Can i sand the corriosoin off and hope it works?
Old Jul 22, 2004 | 09:03 PM
Lyle A's Avatar
Re: What goes out inside the opti?
The corrosion is not normal. There can be tracking, crossfiring. The optical part can be dirty or corroded. Gaskets torn let moisture in. Bearings wear. Replace it since you have it off.
Old Jul 22, 2004 | 09:08 PM
38oldz's Avatar
My guess is the fire from bad rotor makes lots of smog inside the cap that the opti cant see anything no counting fire from rotor all over the place
alphaauto
Jul 26, 2015 04:40 PM
Boss002
Jul 24, 2015 10:47 AM
88IROC_Z
Jul 22, 2015 11:38 PM
RUNMYTA
Jul 15, 2015 07:50 PM
asilomar244
Jul 12, 2015 05:53 AM
