what does a factory set of lt1 heads flow
Old Dec 27, 2005 | 07:19 AM
ghost stripes's Avatar
im thinking of buying a new set of heads and im not sure what to get 195, 210 im stroking this engine out so any ideas would be helpful .....and why dont they have many heads for a lt1 they all try to get you to go with a lt4 which has to have the intake from a lt4 also .....is that correct?.....thanks
Old Dec 27, 2005 | 08:38 AM
rskrause's Avatar
Moderator
Re: what does a factory set of lt1 heads flow
http://www.fierolt1.com/lt1_lt4_headflow.htm
Rich
Old Dec 27, 2005 | 09:03 AM
chrism400's Avatar
There are a limited amount of choices for us and it is frustrating. However, we do have some very good heads to choose from. It all depends on how much you want to spend! AFR makes alot of LT1 stuff, Trickflow makes a 195cc head which is decent. The Edelbrock head which is pretty cheap (under 1000 for the pair) is still being evaluated. There are porters out there that get some crazy flow numbers from the factory heads. Lloyd Elliot, Advanced Induction, TEA etc...A good alternative would be to have Mike Harris in Dayton do them. He has a record setting Impala SS with his own ported LT1 iron heads. His heads work! Of course, you could get a set of SBC heads and have them converted for LT1 use for about 400 bucks.
Old Dec 27, 2005 | 09:51 AM
rock1501's Avatar
I am not meaning to hijack here but I was just wondering if anyone has some real bench flow numbers on AFR 210 comp ported LT4`s.I know they flow less than the wesite says but I just wondered how much less.
thanks
Dave
parkers Z28
Mar 11, 2016 08:14 PM
MadMav
Feb 6, 2015 11:02 PM
Lt1son
Dec 22, 2014 10:58 AM
thenewkid
Nov 29, 2014 04:54 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
