Oilpan smashed
Old Dec 27, 2005 | 03:21 AM
camarolover20's Avatar
Oilpan smashed
Bare with me here its tuff to explain.Me and my buddy just finshed his header install.So we go to take it off the jack stands but as he jackin it down the car fails off the jack smashin the oil pan in and the tq cover shield.So we go to turn the motor over to see if its hitting.Its not but the shield was.Heres the ? how bad can a oil pan be bent in?Its in almost 3 inchs.Will this stop the crank from slinging the oil?Anyone bottom there are out hard?The drain plug is almost flat.Its almost flat with the k frame.No pic witch sucks.How hard is it to change the pan why in the car?Any help plezzz thank u very much!!
Old Dec 27, 2005 | 04:25 AM
SS RRR's Avatar
Re: Oilpan smashed
Oh jeez...
Well the oil pump pickup is probably bent/smashed/damaged as well.
Basically don't start the car again until you can get the oil pan off and see what happened.
Old Dec 27, 2005 | 04:48 AM
oneslowz28's Avatar
Re: Oilpan smashed
yea dont start it untill you pull the pan and just use a hammer and a 2x4 to beat the pan back flat
Old Dec 27, 2005 | 05:37 AM
Re: Oilpan smashed
He has a diff pan already.We was thinkin of pullin the pan jus wanted 2 ask around.
Old Dec 27, 2005 | 09:56 AM
2000GTP's Avatar
Re: Oilpan smashed
The oil pump pickup sits right around the middle of the pan and is pretty close to the bottom so it is possible that you smashed it as well. If you didn't, you still run the risk of sucking a bunch of junk up as sometimes crud can settle on the bottom of the pan and this can become a disaster for you.
Old Dec 27, 2005 | 10:47 AM
1SlowFormula's Avatar
Re: Oilpan smashed
Dan,
Who's car? If you need help PM me I will see if I have some free time. Maybe I camn bring my cherry picker and we can pop the motor mounts off and lift the motor up enough to get the pan out without disconnecting much else.
Old Dec 27, 2005 | 10:56 AM
edunegan95's Avatar
Re: Oilpan smashed
oil pan in the car is not an easy task due to the small windage tray even with loosening the mounts
Old Dec 27, 2005 | 11:21 AM
FastZinTennessee's Avatar
Re: Oilpan smashed
Yea, not an easy task but it can be done. Get the through bolts out of the motor mounts, raise the motor up some. Be sure and take out the low oil level sensor or you will break it when trying to remove the pan(it hangs on the windage tray).
Countryboychevy
Jun 13, 2015 02:49 PM
caspergotaz28
Jul 27, 2003 06:41 PM
miamiheat
Apr 15, 2003 02:18 PM
dust6928
Apr 1, 2003 10:37 AM
witetrashcamaro
3rd Gen / L98 Engine Tech
Mar 19, 2003 07:14 AM
