What do you guys think about these pistons?
Old Mar 30, 2006 | 10:00 AM
sephirothq's Avatar
part number TRW-LW-2256F30
http://store.summitracing.com/partde...5&autoview=sku
let me know what you think
Old Mar 30, 2006 | 07:46 PM
MachinistOne's Avatar
Re: What do you guys think about these pistons?
You get what you pay for...
Old Mar 30, 2006 | 11:14 PM
sephirothq's Avatar
Not to get too flamed here.
but Duh
I know you get what you pay for. I was asking more along the lines for people who might have used them and had good success with them. Not for general thoughts like you get what you pay for or let the buyer beware. Last time i checked this was engine tech not general thougths on life 101
SO to rephrase the question.
Has anyone used these pistons?
Have you had good or bad results?
Some of us don't have stupid money like others to buy $700 pistons to build a $4500 engine for a car that is 10 years old.
Old Mar 30, 2006 | 11:23 PM
rskrause's Avatar
Moderator
They are a good low priced piston and will be fine for a stock rebuild or a mildly modded motor. Suitable for what you are building? Can't say, 'cause you didn't specify.
Rich
Old Mar 30, 2006 | 11:26 PM
playa7970's Avatar
plain words they suck lol just had to do it
Old Mar 31, 2006 | 05:37 PM
sephirothq's Avatar
Good point that i did not say what it is for.
I am going to just do a basic stock rebuild
a gm 845 cam, ported heads, ported intake, 30 lb injectors, 1.6 RR. that is basically it.
I just wanted to know if there was a major problem with using them. If i could afford it i would go for a set of forged SRP.
I figured that these TRW pistons would be better then a stock Gm piston
Old Mar 31, 2006 | 06:40 PM
Built LT1's Avatar
Rich
I second this opinion also.
Old Apr 1, 2006 | 08:46 AM
97WS6SCharged's Avatar
Have you looked at some of the other manufacturer's offerings? Probe offers a nice 2 valve relief budget piston for a 350.
Old Apr 1, 2006 | 10:36 AM
EDS Z28's Avatar
Those pistons should be substantially stronger than stock. Get the speed pro rings to match and you will be set. Are you getting press fit pins or floating? I would get the floating ones myself along with a set of lightweight forged I-beam rods. Or you could just reuse the stock rods with pressed pins and new rod bolts, but new rods are a better way to go, they are the most stressed part in the engine. I've been running speed pro (blower) pistons for about 6 years now with no problems at all.
Old Apr 1, 2006 | 10:53 AM
sephirothq's Avatar
How much does a set of floating rods cost?
Who makes a good set?
At first i was thinking of just reusing the stock rods, having them reconditioned and new rod bolts installed.
Thanks for the comments on the pistons
Old Apr 1, 2006 | 09:09 PM
EDS Z28's Avatar
Check out:
www.scatcrankshafts.com
HectorM52
Jul 30, 2017 11:46 AM
Sergio
Jan 27, 2016 04:27 PM
1963SS
Feb 6, 2015 10:05 AM
bossco
Nov 29, 2014 10:18 AM
Red97LT1
Aug 7, 2002 05:45 PM
