what degree valve locks to get?
Old Sep 4, 2005 | 09:09 PM
Fbody1's Avatar
Question what degree valve locks to get?
which degree 7 or 10 why would i need one over the other? what one is the best for street
Old Sep 5, 2005 | 02:11 AM
MachinistOne's Avatar
Re: what degree valve locks to get?
Different keepers require different retainers....if you have stock retainers or almost any aftermarket street retainer, they use 7 deg. The 10 deg stuff is mostly Ti, or super lock race retainers. The 10 deg will hold up better under higher spring pressures and high RPMs. You can run either on the street, it doesnt matter...just a cost difference. Unless you use Ti super lock retainers though, you will be adding un-necessary weight.
Old Sep 5, 2005 | 02:13 AM
What brand springs and retainers do you have? Single coil? Beehive? Spring pressure? I know you have crane stuff listed in your sig, but I assume you are upgrading....
Old Sep 5, 2005 | 12:48 PM
Fbody1's Avatar
i have crane 10308 double springs no i am not upgrading i will still be using these was wondering about retainers?
Old Sep 5, 2005 | 02:37 PM
1racerdude's Avatar
If ya have super stout springs the 10* will pinch the tip of the stem off and you will loose a valve(800-1000PSI)
Ya don't have that problem so either will work good and no advantage in useing either one.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Roadie
Feb 16, 2015 10:34 AM
