what is this connector and sensor ?
Old Feb 8, 2010 | 02:47 AM
Sporty-X's Avatar
Hello,
when i took my old short block off from my engine, there were a connector going on block plug (passenger side). I dont have them on the new block, plugs are standard on it.
what sensor was on the plug ?
Is it a problem if i dont use it ?
Old Feb 8, 2010 | 05:30 AM
The block drain hole on the passenger side is used for the knock sensor. Unless the knock retard function has been "programmed out" of you PCM, you need the knock sensor. Without the sensor, you get a code/SES light, and continous/variable knock retard.
Old Feb 8, 2010 | 06:40 AM
IOW, you want that knock sensor back on there and connected.
Old Feb 8, 2010 | 11:19 AM
ooooops..... I gues I wasn't being "precise", again......
Old Feb 8, 2010 | 04:47 PM
Sporty-X's Avatar
i'm not talking about this connector.
I'm talking about the one you can see on this pic :
i've no interest in getting rid of the knock sensor.
Old Feb 8, 2010 | 05:04 PM
bw_hunter's Avatar
looks like a block heater...not a problem if you don't use it....
Old Feb 8, 2010 | 05:54 PM
Sporty-X's Avatar
temperature here are never less than 15°C. If it is a block heater i will delete it. I dont beleive having it disconnected can cause a problem ?
Old Feb 8, 2010 | 05:56 PM
Probably would have gotten the correct answer faster if you had included the picture in the first post......
Old Feb 8, 2010 | 06:09 PM
Sporty-X's Avatar
sorry Injuneer.
I wrote the first time in hurry during working time.
Richardan15
May 30, 2015 08:36 AM
94Z28LS1toLT1
May 27, 2015 10:44 PM
Fastbird93
May 22, 2015 08:28 PM
