What Clutch to buy?
Old Apr 18, 2003 | 10:35 AM
Bad T.A.R.A's Avatar
What Clutch to buy?
I have just replaced my clutch one month ago. It is full warranty. It is cheap autozone one though so i don't wan to put it back in there. What clutch should I buy? Can I user the autozone pp/and fly wheel and buy a really good disk???
Old Apr 18, 2003 | 11:31 AM
norcalstreet's Avatar
How much HP are you pushing? Are you more or less still at a stock level?
Old Apr 18, 2003 | 11:33 AM
Ya I think right now 320 at the wheels
Old Apr 18, 2003 | 01:06 PM
Unless you're planning some major HP increasing mods I would get the Stage 2 Star Spec clutch. Anything stronger like a Stage 3 Spec or a Street Twin will make dailing driving difficult.
Is your car a daily driver?
Old Apr 18, 2003 | 01:15 PM
RichJ's Avatar
Why do you say that the Street Twin isn't daily drivable? I have one and it drives great. No chatter and it's easy to modulate, just like stock.
Old Apr 18, 2003 | 01:50 PM
Okay so question here is can I use the cheaper autozone clutch pp / flywheel and just get a good clutch disk?
Old Apr 18, 2003 | 02:00 PM
Brettinator's Avatar
if your really pushing 320 rwhp (key word Rear Wheel) I would not even bother with a stock clutch, spend the money do a McLeod or Centerforce, do it right.
Old Apr 18, 2003 | 02:09 PM
93Z286Speed's Avatar
Note: centerforce is not doing it right.. there clutchs are JUNK. Personally i have the SLP PP and disk.. works great for me
Old Apr 18, 2003 | 02:14 PM
thanks, I personally like the McLeod but I'll check out the SLP now too.
Old Apr 18, 2003 | 02:25 PM
rskrause's Avatar
Moderator
An OEM clutch is what I would chose for 320rwhp. If I wanted something better than the stocker, the Street Twin is by far the best clutch out there for an LT1 4th gen. It would last forever with 320rwhp and would be overkill. For something in the middle, it's tough. There are a lot of people who haven't had good luck with Centerforce or Spec. You might check the McLeod catalog to see if the make something else besides the ST for the LT1 4th gen. They make a good clutch.
Rich Krause
Old Apr 18, 2003 | 03:51 PM
RichJ's Avatar
I'd either get something inexpensive like a stock set-up with a McLeod dual friction disk or get a Street Twin...not something semi-expensive like the Spec. You can bet that the Spec will _not_ be the last clutch you ever do and yet it is more than 1/2 the cost of the Street Twin. I vote Street Twin
RichJ
Matt W
Apr 24, 2015 12:54 AM
blkWidow
Apr 21, 2015 01:56 PM
BPS
9
Mar 5, 2015 10:51 PM
HectorM52
Jan 30, 2015 11:08 PM
