What causes idle speed to increase every 10 seconds?
Old Apr 20, 2004 | 07:44 AM
Bob 97SS's Avatar
Question What causes idle speed to increase every 10 seconds?
The idle is smooth but increases a few hundred rpm every 10 seconds. Then it drops back to normal and the process starts all over again. No codes. IAC count is around 80.
Old Apr 20, 2004 | 08:38 AM
badblackta's Avatar
it is the IAC sensor. My moms z does the same thing. The car trys to lunge forward.
Old Apr 20, 2004 | 08:43 AM
scoobysnax83's Avatar
I would go with a vacuum leak as well. If there is a leak then the PCM is using the IAC to compensate for it. That may be why you (badblackta) think it is the IAC.
Old Apr 20, 2004 | 08:48 AM
badblackta's Avatar
just sounded like the same thing going on with my moms z28, the exact same thing. And there are no vacuum leaks. Not ruling out the possibility of a vacuum leak on this car though
Old Apr 20, 2004 | 08:52 AM
it could definitely still be the IAC, I wouldn't rule that out, but check for the obvious first like leaks. You should clean your IAC as well. Try a little carb cleaner on it
Old Apr 20, 2004 | 02:34 PM
BarnesGN's Avatar
This might sound stupid but try it, check for any exhaust leaks before the o2 sensor.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
edman
Jan 25, 2015 02:41 PM
pete53
Dec 9, 2014 07:31 AM
