coolant leak after opti install help!!
Old Apr 19, 2004 | 07:03 PM
cridom's Avatar
hi after the opti install and bleeding the system everything was fine but after 2 days driving 20 miles a day i saw some coolant on near the bolts on the WP and near the t-stat thing and also some in the intake elbow on the top of it so im guessing is some hose or something. i dunno if i messed up but i didnt put any sealant on the t-start thing cuz i didnt see any there to begin with im not gonna drive the car cuz im scared to crap the opti out. thanks.
Old Apr 19, 2004 | 09:39 PM
cridom's Avatar
ttt
Old Apr 19, 2004 | 10:11 PM
The thermostat housing does not use a gasket, but there should be a good o-ring on the thermostat, itself. Also the housing sealing surfaces should be debris free so it can seal. The small bolts are only torqued to 89 lb. in.
Thread sealant should be used on the water pump mounting bolts.
Old Apr 19, 2004 | 11:06 PM
cridom's Avatar
thanks shoebox you helped me a lot on the opti install. if i remove the waterpump and reinstall it am i gonna damage the new opti?
Old Apr 19, 2004 | 11:13 PM
Not unless you soak it with coolant and it is not well sealed. If coolant is only seeping out the bolts, you might try just putting some sealant on the bolts and reinstalling them. You will still have to drain coolant, so it does not pour out when you remove the bolts, but you won't have to remove the whole pump. If the pump gasket(s) is(are) leaking, that's another story.
Old Apr 19, 2004 | 11:20 PM
RENE95Z's Avatar
You are more than likely leaking from your waterpump somewhere. Having coolant where you described seeing it kind of sounds like it is coming from the weep hole where it drips directly onto the serpentine belt and slings the coolant everywhere. Hopefully it is like Shoebox has directed to with a leak coming from a bolt that just needs a little coersion with some sealant.
Old Apr 20, 2004 | 11:11 AM
cridom's Avatar
i didnt put any kind of sealant but how could the coolant get to the top of the intake elbow??
Old Apr 20, 2004 | 11:15 AM
blown383's Avatar
Check to see if your bleeder screws are on tight...I wouldn't be surprised if it was pissing out coolant.
-B
Old Apr 20, 2004 | 02:41 PM
cridom's Avatar
thanks apparently it was that. vuz the one near the tstat was loose by about half turn. it was still tight but not all the wayy. i watched it for about 15min and it didnt leak anywhere. i also cleanned the TB with some TB cleanner spray and my TB response is a lot better thanks.
calaban
May 18, 2020 06:43 PM
Alex Barnes
Jan 24, 2015 10:21 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
pologreen97z
Dec 2, 2014 10:42 AM
