what can i do for improve my camaro 4a lt1 1994
Old Oct 6, 2005 | 11:48 PM
camarohg's Avatar
hi, i´m form venezuela and i have a camaro 4a z28 lt1, i wanna know what kind of modification i can do for improve the car performance, but the car be always for street race, what kind of valve train i can use or camshaft, what kind of programation, what kind of suspension and all the improvement that i can do, bye
Old Oct 7, 2005 | 12:09 AM
Kurt Crosbie's Avatar
Re: what can i do for improve my camaro 4a lt1 1994
Start with suspension, work your way to bolt-ons, then go into engine internals.
First get aftermarket lower control arms, panhard rod, and shock brackets. Then get a 12-bolt and aftermarket torque arm. Get some drag springs and shocks.
-switch to a stage 3 clutch
-go with a higher stall (around 3000) or get an manual tranny
-rebuild the auto tranny if you're going to stay auto
-full exhaust (longtube headers and dual exhaust)
-full intake (cold air intake or ram air intake)
-electric water pump
-underdrive pulley
-ignition box
-coil
-over the valve cover plug wires
-airfoil
-throttle body coolant bypass
-port and descreen maf
-port throttle body
-1.6 roller rockers
-big cam shaft
-hardened pushrods
-big lift springs
-rev kit
-better valves
-clean up heads
-get heads max ported
-custom grind cam
-get lt4 head gaskets (this will up your compression to 11.5
-stroke the bottom end
-get a tune by ion soltan
or....
get a turbo system!
Old Oct 7, 2005 | 07:48 AM
2000GTP's Avatar
-underdrive pulley
-ignition box
-coil
-airfoil
-port throttle body
-1.6 roller rockers
-big cam shaft
-hardened pushrods
-big lift springs
-rev kit
-better valves
-clean up heads
-custom grind cam
or....
get a turbo system!
Everything he said . The suspension in addition to some good tires is a great way to start.
Red Hawk 94
Mar 18, 2019 04:03 PM
Noenav
Mar 1, 2019 07:38 AM
SinisterRacing1
Mar 7, 2015 03:44 PM
Scottylt1
Jan 8, 2015 02:48 PM
Jul 4, 2005 05:00 PM
