what are the best main and rod bearings for lt1?
Old Jun 9, 2010 | 11:21 PM
z28beast's Avatar
Exclamation what are the best main and rod bearings for lt1?
ok so i had federal mogul bearings in my motor but since i recently had to pull the pistons again i decided that i want the best bearings i can get for my motor. i heard clevites are good but i dont know what series is the premium ones...also fwiw the crank is going to be 10-20 under
Old Jun 10, 2010 | 09:11 AM
rskrause's Avatar
Moderator
King or Clevelite. If you have a crank with generous fillets you need a chamfered bearing like the "H" series.
Rich
Old Jun 10, 2010 | 12:10 PM
I'll vote for the King Alecular.
http://www.kingbearings.com/advantages.html
Old Jun 10, 2010 | 01:50 PM
z28beast's Avatar
Rich
thanks for the reply brother....and what do u mean by fillets?
Old Jun 10, 2010 | 03:49 PM
Rob94hawk's Avatar
Never heard of King bearings. Learn something new everyday.
Old Jun 10, 2010 | 04:17 PM
brucer's Avatar
fillets are also known as radius' on the crank journals.
fillet or fillets are actually the properly used term..
Old Jun 12, 2010 | 01:08 AM
MachinistOne's Avatar
I only use clevite - never have had a bearing caused failure so I'll stick with what works.
D1SC383LT4
Jan 26, 2015 01:41 PM
PaulN64
Aug 8, 2002 05:39 AM
PaulN64
Aug 7, 2002 06:17 PM
