What all is involved with changing opti seals?
Old Jul 15, 2004 | 05:27 PM
Loadre's Avatar
Can I just pull the crank pulley, pull the opti, change seals and button it back up?
Does the waterpump have to come off at all or anything else?
Brian
Old Jul 15, 2004 | 06:36 PM
The water pump has to come off before you can get the opti off. You can change all the seals in the timing cover, though you will have to remove the crank hub if you want to do the crank seal.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
PCLZ28
Dec 24, 2015 05:19 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
