Wet Distributor
Old Jul 25, 2004 | 05:32 PM
two converts's Avatar
Wet Distributor
I washed my engine (94 Z28) and now it won't start, the distributor is wet. Is it a bear to dry out?
Thanks, Ralph
Old Jul 25, 2004 | 06:57 PM
Trmpt63529's Avatar
Re: Wet Distributor
its probably just your plug wires.... try taking them off at the coil pack...(behind harmonic balancer) and spray WD40 in them... thats what that stuff was originally made for....displacing water in airplane carbs.
Old Jul 26, 2004 | 06:29 AM
Re: Wet Distributor
I'm afraid it's not the plug wires. I fans on it all night and it still does the same thing. The question remains...What do I have to do to get at it???
Thanks!
Old Jul 26, 2004 | 09:36 AM
quicksilver97ta's Avatar
Re: Wet Distributor
The optispark distributor is probly toast.
Old Jul 26, 2004 | 11:35 AM
Re: Wet Distributor
The first rule of owning an LT1 is DO NOT GET THE OPTISPARK WET! A big puddle, a high pressure car wash, coolant drips from the water pump weep holes, slopping coolant when changing a hose, etc are all potentially fatal actions as far as the Opti is concerned. The 95 and later "vented" models are a little more forgiving, because of the air flow through the unit.
Pouring water on the engine is never a good idea, and when you've got a 10-year old, computer controlled EFI/ignition setup, with aged connectors and dried out water seals its a really bad idea.
Old Jul 26, 2004 | 11:40 AM
Re: Wet Distributor
Ok, So the question still remains...How big of a job is it???
Old Jul 26, 2004 | 12:24 PM
Trmpt63529's Avatar
Re: Wet Distributor
i think you have to pull the harmonic balancer... in any case you can't dry it out without taking it off... you may be able to spray wd40 on it. that stuff was made to displace water, in other words it will move the water out of it. if you want to wash your engine, only do it while it's running.... i used to detail cars and you can wash most any motor as long as it's running..
Old Jul 26, 2004 | 12:47 PM
94Zpower's Avatar
Re: Wet Distributor
I just changed my opti and wasnt that bad it takes about 4hrs, you have to pull the water pump and coolant lines then the Crank pully and pass side colling fan, and the rev to put it back together, its not hard just alittle long and you might get wet with coolant.
68camaroboltz
Oct 5, 2015 01:46 PM
autoxr166
Sep 25, 2015 04:21 PM
karpetcm
Sep 15, 2015 11:07 AM
gonzo275rltw
Jul 11, 2015 04:19 AM
Boss002
Jul 9, 2015 03:33 PM
