Wet comperssion test did not help...
Old Jul 23, 2004 | 06:06 PM
BLUETOPTA's Avatar
Unhappy Wet comperssion test did not help...
I have very little comperssion on cylinder #1. Did a wet comperssion test and it did not help. Other cylinders are ok. no coolant leakage. I have had my heads ported and polished w new seals but stock valves a little less than 10k miles ago. Im thinking it has somthing to do with the valves. what kind of problems have people had with the valves being bad on these engines. I searched but didnt find much.....
Old Jul 23, 2004 | 06:56 PM
Re: Wet comperssion test did not help...
A sealing problem other than rings. Could be valve seats, cracks, even head gasket. How about a leakdown test? That might help determine where the compression is going, if you can hear it well enough.
Old Jul 24, 2004 | 07:13 AM
BLUETOPTA's Avatar
Thanks for the reply... this all started to happen ( the car running bad) after I got rear ended. I didnt see you mention anything bad w the valves as a possibilty? could they be burrned or have crack in them? Do you know where I could borrow a leak down tester??
Old Jul 24, 2004 | 02:04 PM
BLUETOPTA's Avatar
I have the header and intake manifolds off now..... on the #1 exhaust port there is A LOT of black gunk? im thinking thats gas. the #1 intake port is clean. Maybe i have a bad exhaust valve?
Old Jul 25, 2004 | 10:27 PM
Trmpt63529's Avatar
this is an easy way to find the leak if you have the right compression gauge.... take the end off of it (spark plug hole side) and put an air fitting into and hook it directly to an airline...(if you have a compressor) and you should be able to hear where it's coming out at.... first check outside for the headgasket then if you don't find it, check under the valve cover for leaky valves....
karpetcm
Sep 15, 2015 11:07 AM
meissen
Aug 11, 2015 06:05 AM
realistyc
Jul 28, 2015 07:32 PM
Boss002
Jul 9, 2015 03:33 PM
