went to the track again
Old Aug 11, 2003 | 11:54 PM
  #31
Quickshotkimber's Avatar
Originally posted by Fastbird93
That's the common misconception that has people not being as fast as they think they should be and pissed off about it. Just throwing a bunch of big aftermarket parts on a car in random order does jack except make you look like an idiot who doesn't know anything. I'm NOT calling you that by the way.
It's been shown before that ported maf's don't really help out unless it's a high hp motor, and that if you do insist on getting one, tuning is a must.
As it sits, if you can get a good launch, you should be mid-low 13's.
Good job keeping them straight. I think the stocker flows around 930 cfm. Good luck trying to tune a ported one. Most mail order guys won't touch it because it is just guessing.
I would add, but I think you have already made up your mind about your car.
Old Aug 12, 2003 | 12:01 AM
  #32
viperkiller's Avatar
i have a ported maf with cam and couple extras
if you contact 97Z-M6 he has my program and he'll e-mail it to you i'm sure. it's not exactly what you need but can get you close enough that you can adjust the fuel or whatever you need to get it riight
Old Aug 12, 2003 | 04:51 AM
  #33
No two ported mafs are the same, that is the problem. The sensor will not read air correctly.
Old Aug 12, 2003 | 07:17 AM
  #34
97Z-M6's Avatar
yes and no. yes they are not exactly the same. but most of time they are real close unless someone damaged the maf. this bin file will get you close after all madwolf or pcmforless will correct a ported maf through a mailorder tune. so they cant be far off.
if you want the bin file i can send it to you and you can inport the tables into your tables
Old Aug 12, 2003 | 01:11 PM
  #35
jer4251's Avatar
i do not have a stock ported MAF, i have the one tybrne sells. its an aftermarket one.
Louey
Pacific
Oct 1, 2015 12:37 AM
NewsBot
Sep 16, 2015 10:30 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
Louey
Pacific
Sep 1, 2015 07:19 PM
Louey
Pacific
Aug 25, 2015 01:53 AM
