weld rim back spacing?
could someone tell me what backspacing you need for the f body with the 15" weld rims. i need backspacing for the front runners 15x3.5, and for the 15x8's and 15x10's as well. and also what is our bolt pattern? thanks in advance
15x8 = 5.5 b/s
15x10 = 6.5 or 7.5 (7.5 needs more inner fender beating)
5x4.75 bolt pattern if my scattered memory is correct.
front runners are usually a fixed backspace,i just looked in jegs and they are fixed backspace,just depends if you want the 3.5 or 4" wheel.
This is a 15x10 Pro-Star with a 7.5" backspace. Going to a 6.5 is going to push it out an inch more.... depends how you want it to look.
For the full picture, click on "Trailer Queen...." in the signature.
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
squarehead
Nov 21, 2014 08:02 PM
