weird rubber-rubbing sound
Old Jan 18, 2005 | 08:06 PM
DataChild's Avatar
Whenever I give it a good launch, whether it be WOT or 50-75% WOT, there is a sound in the front of my car, like rubber rubbing. Like a big squeak almost... imagine opening an old wooden door and it be like creeeeeeeeeeeek. It lasts for about a half second to a second... I thought this was balljoints, but i had them replaced today! (upper)
I do need new shocks, could this be it? its quite annoying
Old Jan 18, 2005 | 08:20 PM
red 95 z28 lt1's Avatar
Re: weird rubber-rubbing sound
does it happen when the car shifts into 2nd at wot, you may have a worn belt or a loose belt tensioner. i am on my 2nd tensioner
Old Jan 19, 2005 | 01:56 AM
DataChild's Avatar
defenitly sounds and feels like a front suspension part, however i could be wrong. any other ideas? ;/
Old Jan 19, 2005 | 05:25 AM
Dave89IROC's Avatar
tie rod or sway bar bushings
Old Jan 19, 2005 | 05:37 AM
scoobysnax83's Avatar
I vote front shocks. I am going through the exact same thing now that it is cold out. Mine also makes the noise when I hit a large dip in the road. Is it cold where you're at?
Old Jan 19, 2005 | 10:14 AM
BoobSter-lt1-z's Avatar
I had the exact same sound on the rear...sounds like a worn out bed when you first lay in it but without the metal squeeking...my rear shocks have a dried black substance coming out. THe front ones just did it recently too. I checked this by pushing the car down from the front and then the back. I also think i need new shocks.
Old Jan 19, 2005 | 10:21 AM
stealthtt's Avatar
A friend of mines camaro was doing about the same thing and it ended up being a broken sway bar bracket.
Old Jan 19, 2005 | 10:23 AM
fesgali's Avatar
I do it also but it's just the rear tires
Old Jan 19, 2005 | 12:03 PM
DataChild's Avatar
yes, its extremley cold. i live near detroit...
well, i plan on getting new shocks anyways. if that dont solve it, then the other solutions you guys suggest dont seem all that difficult/expensive. Thanks!
Nayr
Mar 3, 2023 08:34 PM
94Maroz28
Oct 27, 2015 04:38 PM
PopoFormula
Oct 12, 2015 04:19 PM
4586
Sep 27, 2015 01:55 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
