Weird problem after tune.
Old Dec 15, 2014 | 06:02 PM
97SSdude's Avatar
I installed kooks LT's on my 97 SS and I removed egr and air. I had PCM4less tune the ecm to remove the egr and air. I put the ecm back in and car started fine and runs fine. Problem is when I'm going down the road and shifting gears (M6) the rmp's dont seem to drop quick and sometimes they increase a few hundred rpm's before they start to drop. But before they drop enough I have already shifted gears and the car jumps because the rpm's are still alittle high. I was wondering if anyone had an idea what this could be? Is it because I removed the egr and air? Thanks!
Old Dec 17, 2014 | 10:09 AM
maybe2fast's Avatar
Re: Weird problem after tune.
sounds like a vacuum leak
Old Dec 17, 2014 | 11:08 AM
I'm assuming these are lifting throttle shifts.
The PCM opens up the IAC valve as RPM increases, to prevent the engine from stalling if the throttle blades close suddenly. I think the way the IAC reacts to this is controlled by something called the "follower tables". Sound like it might be a programming issue.
Old Dec 17, 2014 | 02:07 PM
Mystery Bird's Avatar
I agree, either vacuum leak of the throttle follower vs. IAC vs. speed table.
Old Dec 18, 2014 | 09:22 AM
97SSdude's Avatar
Ok thanks guys. I guess I'll give PCM4less a call or email and see what they say.
Old Dec 18, 2014 | 09:44 AM
maybe2fast's Avatar
Is your air duct on properly?
Old Dec 18, 2014 | 11:13 AM
97SSdude's Avatar
Yes the duct is on. Everything seems to be where it's supposed to be. This all started when I got the tune. I just thought someone on here had a thought of what it might be before I contacted pcm4less.
Old Dec 30, 2014 | 10:22 AM
97SSdude's Avatar
So I heard back from pcm4less and they told me to check tps voltage? I don't see how this could be the problem when it was fine before the tune? I have a feeling I shouldn't have let them tune it now.
Old Dec 30, 2014 | 12:14 PM
Since it's so easy to check the TPS sensor, why not give it a try?
Harness unplugged, key on, do you have 5V between the black and gray wire pins in the harness connector?
Harness plugged in, is the closed throttle voltage between 0.30-0.80V across the black and dark blue wires?
Slowly open throttle blades, watching voltage. Voltage should increase slowly, with no dropouts or spikes, until the throttle is wide open. WOT voltage should be about 4V higher than the closed throttle voltage.
Old Dec 31, 2014 | 07:43 PM
ACE1252's Avatar
Also make sure your throttle is not hanging up in some way(bad throttle spring...etc).
timmy39120
May 8, 2015 11:41 AM
Cam's maro
Mar 24, 2015 08:09 PM
Dylan Latshaw
Mar 21, 2015 09:48 AM
Magenta_Hearts
Mar 5, 2015 07:01 AM
97z28k&N
Jan 9, 2015 04:58 AM
