24x efi harness questions
Old Apr 9, 2013 | 06:10 PM
Greg88's Avatar
Ok, so here is my story, I bought an LTx motor with a 24x efi system on it running with the LS1 PCM. I am getting the harness with the motor, only problem is the harness is a 94. I have a 97 trans am. I have since bought an extra 97 harness to repin. Will i need to get more connectors for my 97 car? OR can I just remove all wires/connectors from the 94 harness and put them on the 97 harness?? Thanks for all the help!
Old Apr 11, 2013 | 06:05 PM
Greg88's Avatar
Re: 24x efi harness questions
No one on here is running the 24x efi system?
Old Apr 12, 2013 | 12:19 AM
ascastil's Avatar
theres a few on tech that are, might wanna try there. or you can just call efi and they can tell you.
Old Apr 13, 2013 | 12:49 AM
97WS6SCharged's Avatar
You shouldn't need to change anything. The repinned 94 harness should run any LT1 with the 24x conversion. The only reason you would want to change anything would be to remove any unused connectors.
Old Apr 13, 2013 | 08:51 AM
Skedaddle's Avatar
Would there be a possibility of issues with minor variations in the interface to the body connectors? Shoebox has the pinouts for all years:
http://shbox.com/1/harness_connector_faces.htm
Old Apr 14, 2013 | 07:18 AM
Greg88's Avatar
Well, i think im going to switch over the connectors to the 97 harness, it has more connectors on it (top of passenger side wheel well) so i think ill convert it to the 97 i guess, just need some schematics i guess
Old Apr 15, 2013 | 05:05 PM
daddyoisback's Avatar
use the 97' and get the printouts just google it there everywhere i have a stack printed out lol plus the 94' harness doesnt have what you need for the trans the 97' will but you didnt say auto or stick
Old Apr 15, 2013 | 08:34 PM
Greg88's Avatar
ok thanks! both harness' are stick. I just pulled the 94 harness off the motor tonight, hopefully get to it this week!
Old Dec 31, 2014 | 11:25 PM
cswamblez28's Avatar
You still have harness?
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
willismoons
Feb 14, 2015 08:42 PM
Queens94z28
Dec 20, 2014 09:11 PM
