Weird no spark problem
Old Jan 1, 2011 | 08:54 PM
marshall93z's Avatar
Car left me stranded New Years Eve with a no spark condition.
Now, the problem seems to be intermittent. I have the pulse coming to the ICM(I have a spare opti I turn real slow to test this) and 12 volts on A and D, as well as a ground on C. This is with the connector unplugged.
The weird part is that when I have spark coming off the coil wire(with ICM connector plugged in), I also have good voltage on pin B, but when the car dies and there is no spark, I hook up my spare opti and the signal is very weak on pin B. But ONLY with the connector plugged in. I can unplug it and the voltage is fine.
Intermitten problems SUCK!
Thanks in advance for any help!!
Old Jan 1, 2011 | 09:29 PM
my1994z28's Avatar
Re: Weird no spark problem
Possible that the opti harness has a broken or damaged wire?
Old Jan 2, 2011 | 09:46 AM
Probably not, since I'm getting the signal from the PCM to the ICM. Maybe the ICM is failing when it gets hot.
Does the ICM have to be mounted to the coil bracket, or can it just be hanging out in the middle of nowhere?
Old Jan 2, 2011 | 11:09 AM
It's definitely looking like ICM. I can heat it up and no spark... cool it off and I get spark again.
It actually gets warm with just the key forward... no idea why it would do that?!?! lol
Old Jan 2, 2011 | 05:58 PM
popstoy's Avatar
heat will expand bad connecters also.check your wires i had stupid problems with worn connecters.
Old Jan 2, 2011 | 06:05 PM
my1994z28's Avatar
If its the Icm,make sure you use the di-electric grease on the back side.
Old Jan 16, 2011 | 03:43 PM
It was the ICM.
Old Jan 16, 2011 | 06:12 PM
You don't use dielectric grease. You use heat transfer grease (or more correctly, compound). Two different things.
greenzee28
Mar 26, 2015 09:13 AM
Dylan Latshaw
Mar 21, 2015 09:48 AM
grabbem88
Mar 18, 2015 01:25 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
97z28k&N
Jan 9, 2015 04:58 AM
