Weird Heat problem - please advise
Old Jul 26, 2006 | 12:33 PM
catsnet's Avatar
Question Weird Heat problem - please advise
car - 94Z28 (less then 60K. New clutch - McLeod about 10K still chattering like crazy, tranny fluid changed 5K ago)
After considarable city drive (trafic, stop & go. E.T.S) I have some very notisible heat comming out from the shifter (Hurst) area which I can fill with my hand on the shifter. Also the metal stick from the shifter is geting rally hot to touch. Also some serious heat comming out from under the car on the passanger side. Oil and water temp is showing OK. Also I noticed that it only happenning when I have 1/4 of the fuel in the tank or less (highly unlikely has anything to do with it - but still nefer happens with more then a 1/2 tank full)
Beside the tranny fluid - will recheck again, what can be wrong?? Can it be a cat by any chance??
Old Jul 26, 2006 | 02:32 PM
OBE1 95Z28's Avatar
Re: Weird Heat problem - please advise
I'd say that's normal; your cat is located close to this area.
Old Jul 26, 2006 | 03:32 PM
catsnet's Avatar
just wondering why never happend before
Old Jul 26, 2006 | 05:20 PM
deputydough's Avatar
maybe the cat is stopping up and getting hotter.
Old Jul 27, 2006 | 09:32 AM
catsnet's Avatar
You mean clogged??
Cam's maro
Mar 24, 2015 08:09 PM
kksi
Feb 17, 2015 10:41 PM
chuyz28
Jan 27, 2015 08:53 AM
Jan 23, 2015 01:13 PM
97z28k&N
Jan 9, 2015 04:58 AM
