Weird Coolant Leak!please Help!
Old Oct 22, 2003 | 10:12 PM
DarkRider's Avatar
OK
about a month ago my low coolant light started popping up out of nowhere. So I filled it up with coolant and it did the same thing again. Looking at it closer when I turn the car off after about 10 minutes coolant starts to leak out of the top of resorvoir tank (quite a bit) and even with the coolant low every time I turn the car off it will leak out a bit more. I drained the coolant flushed the system and refilled it and let it run with the cap off for a while to maybe let any air pockets out?RIGHT?. It ran good for two days and then started leaking again. I can't figure it out. Would air in the system cause this??
Also I am running a 160 Thermostat and the car runs at a little over 210 ?NORMAL?
Thanx
Josh
Old Oct 22, 2003 | 10:17 PM
FastZinTennessee's Avatar
That's really odd.
160 thermo and 210* operating temp is NOT normal.
Any white smoke coming out of the tailpipes?
Old Oct 22, 2003 | 10:20 PM
DarkRider's Avatar
No smoke oot the pipes, just off the tires
Terran2k's Avatar
try to change ur radiator cap.
Old Oct 22, 2003 | 10:23 PM
DarkRider's Avatar
the cap would let too much coolant back to the resorvoir(how the heel do you spell that)?
Old Oct 22, 2003 | 10:26 PM
WadeC's Avatar
Make sure your high speed fans are working.
Old Oct 22, 2003 | 10:34 PM
Wild1's Avatar
You left the cap off to let out any air pockets...
That is part of your problem. There are two specific bleeder valves which must be opened after each service.
Also, not all 160* thermostats are for reverse cooled LT1 heads. There is an extra piece on LT1 Thermostats to operate the reverse cooling system.
Excess water in the reservoir is unusual. If you replenished the fluid to the proper level, it should not overfill. The only reason it would run over is due to air being introduced into the system. It could be due to several reasons....
With the engine cold, take off the radiator cap then start the car. As it warms up and the thermostat begins to open after a few minutes, do you see any air bubbles? Do that check and we'll go to the next step.
Old Oct 22, 2003 | 10:44 PM
DarkRider's Avatar
I don't understand ?REVERSE COOLING SYSTEM?
Old Oct 22, 2003 | 10:48 PM
AsianSensation's Avatar
Coolant goes to the heads first before the block.
Old Oct 22, 2003 | 10:50 PM
RUFFIDLNZ's Avatar
Our coolant goes to the heads first then to the block. It does this to help prevent warpage on the aluminum heads.
Old Oct 22, 2003 | 10:54 PM
Or to lessen the likehood of detonation so we can run 10.5:1 compression on unleaded gasoline.
blac94Z
Feb 15, 2021 09:43 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
Blood type Z28
Apr 8, 2015 11:34 PM
97z28k&N
Jan 9, 2015 04:58 AM
dansam
Jul 20, 2002 01:10 PM
