Way to rich
Old May 18, 2006 | 09:58 PM
jonlil77's Avatar
Way to rich
Finally started new 383 and it initially ran for approx 10 minutes with a little help to the throttlebody,but stumbles and dies and wont fire back up.It will fire if i pull the injector fuses crank it with tbody all the way open runs for couple sec then dies.But if i put the injector fuse back in and wait 10 min crack the tbody open to start it she'll run for maybe 5 min while varying rpm 2000-2500 or so then dies. Fuel pressure is 45 psi while sitting there when system is primed just after turning key and holds it well and maintains good psi while trying to run this thing but varies slightly while varying the rpm's.Exhaust is totally black ,plugs are wet and black also.the plugs are ngk bkr6e-11 are these too cold and contribute to the problem?This is thru an AS&M open header with no O'2 sensors hooked up,pitched old and didn't get new yet.There are no visible leaks such as at the header flange,at the injectors,vac,intake.Drained the oil and was black and alot mor came out then went in.Motor has all new wires,opti,everything but iac ,tps and maf sensors.Also pcmforless tune which Alvin left psi on fpr at 45 so fuel pressure is not the problem i don't think.here is a basic list of the mods .All parts are new .Got any ideas? Mechanically seems fine,no probs 11.5 comp 383
AFR LE ported to 217cc lt4 heads
cc306 cam
SVO 30 lb injectors
MSD coil
NGKbkr6e-11 plugs
Holley 58 mm tbody
Taylor wires
meizer h2o pump
Old May 19, 2006 | 09:58 AM
Re: Way to rich
Is your coolant temp sensor connected, and providing the PCM with an accurate coolant temp?
Old May 19, 2006 | 02:53 PM
jonlil77's Avatar
Re: Way to rich
Yes the coolant temp sensor is hooked up
Old May 19, 2006 | 02:59 PM
jonlil77's Avatar
Re: Way to rich
this is a 93 by the way
Old May 19, 2006 | 03:25 PM
Re: Way to rich
What about the other part of the question?
drt
Sep 27, 2015 04:39 PM
greenzee28
Sep 25, 2015 04:29 PM
HAWG
Sep 25, 2015 11:41 AM
damnyankee36
Sep 9, 2015 07:06 PM
