water pump failure doing surgery at 141k miles
Old Jun 23, 2019 | 08:24 PM
  #16
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
Re: water pump failure doing surgery at 141k miles
Can the Accel be returned without paying exorbitant shipping and restocking fees? I wouldn't want to put one on my car, but our choices seem to be pretty limited these days.
Old Jun 24, 2019 | 10:10 AM
  #17
Phoenix'97's Avatar
Originally Posted by pearlpurple
Thanks. I am a little nervous now with the ACCEL but will take your advice on the dielectric grease.
I went in and changed the timing chain set so timing cover is off and oil pan in dropped some to gain the access. So will be changing all three seals (ordered the water pump tool off of Ebay)
Now that I have the pan dropped I want to pull the pan off all together as I don't like the way the front of the oil pan gasket looks and I think it leaks anyways. How high do I need to raise the engine to get the pan to clear the crank shaft and oil pick etc.??? I also want to check my oil pick up screen/tube as I have that infamous oil pressure drop when flooring it from a stop.
Thanks again
Do you have the car on a personal car lift or at least on ramps? Otherwise, I think jacking the car up as high as you can with support stands should be more than enough to be able to get the pan removed and clear the crank and pick up.
Old Jun 24, 2019 | 12:08 PM
  #18
Jacking the car does not increase the clearance between the oil pan and the K-Member.
Old Jun 24, 2019 | 02:12 PM
  #19
Phoenix'97's Avatar
Oh, is he asking for a clearance increase?! If he doesn't want to drop the engine and he is very limited on lifting options like I am, here is some more help for him...
https://ls1tech.com/forums/lt1-lt4-m...g-oil-pan.html
Old Jun 24, 2019 | 03:40 PM
  #20
Helps if you read all the posts in a thread, so you know what's going on.
Old Jun 25, 2019 | 01:42 AM
  #21
Phoenix'97's Avatar
Oh, you didn't pick up on my sarcasm with my previous post. Yes, I read it through! Yes, there are "red-neck backyard mechanic" ways to remove the oil pan. I provided a link for the original poster to digest depending upon the tools and options available to him. That is all. I don't play the role of Captain Obvious, I comment information that I feel will be helpful to the posters of these threads and usually you search cross-forum to get as much information as you can.
Old Jun 25, 2019 | 10:43 AM
  #22
So...... you feel we are all a bunch of “redneck backyard mechanic(s)” or you feel we are giving “Captain Obvious” responses? Interesting.
And no, I did not detect any “sarcasm” in any of your posts.
Old Jun 25, 2019 | 04:29 PM
  #23
Strick's Avatar
My suggestion: go with an electric water pump from Meziere. Get the HD.
Old Jun 25, 2019 | 07:46 PM
  #24
pearlpurple's Avatar
I have searched many message boards
My plan is to remove tranny mount bolts, catalytic converter bolts, y pipe at flanges, remove motor mount bolts, have already removed torque converter inspection cover, oil pan bolts are out, I understand #6 piston needs to be at TDC,,,,
What am I missing as in are there a/c lines, or other lines or wires or something else
I understand I can get maybe 4 inches extra from normal engine position
What else guys??
And even if I was a back yard red neck mechanic I have met and worked some pretty bright people who might be red necks
Old Jun 25, 2019 | 07:51 PM
  #25
One of the potential entrance points for coolant is the tower for the main Opti harness connector. It's pointed up, right near the pump weep holes. That has to be addressed as well.
Going to use dielectric grease on that one Fred, but not too much just enough to live the plug and have a bit of excess to keep dust and moisture out
Thanks for that nugget
Old Jun 26, 2019 | 02:01 AM
  #26
Phoenix'97's Avatar
Where did I say in my quote that I felt the members of this forum were "redneck backyard mechanic(s)"?! Here is my quote regarding your interpretation. Quote, "Yes, there are "red-neck backyard mechanic" ways to remove the oil pan." Where do I make the assertion that I "feel" anyone is a red-neck backyard mechanic?! Please read my comments in full.
My quote regarding "Captain Obvious", quote, "I don't play the role of Captain Obvious, I comment information that I feel will be helpful to the posters of these threads and usually you search cross-forum to get as much information as you can." Where does your comment contribute to this thread? I have made my point!
@pearlpurple
I am sure you have worked with plenty of intelligent mechanics. Please don't let Injuneer's comment and misinterpretation of what I stated make you think less of me in my attempt to give you some useful information, assuming it was. I don't know!
Old Jun 26, 2019 | 04:36 AM
  #27
@pearlpurple
No worries thanks.
Old Jun 26, 2019 | 08:42 AM
  #28
OK..... I'll drop out to avoid further conflict. Good luck.
Old Jun 26, 2019 | 11:45 AM
  #29
Chimera96's Avatar
OP
PM Injuneer if you have a ? as his experience is SIGNIFICANTLY more than Phoenix...
My $.02 on the dialectic grease. On connectors use it on the accordion rubber seal that goes on the ends of these connectors to assist in preventing fluids entering the cavity of the connector
On Opti, use it on the large O rings that the cap & case sandwich vs just smearing it on the outside of the opti seam
The FelPro one piece pan gasket is very good. Confirm the metal spacers within the old pan gasket came off with that old gasket and none are still on the rear studs of the RMS adapter. They are small and if you miss one the new gasket will not seal
I wipe both the engine block and pan with acetone a few times before installing new gasket and RTV
The FelPro pan gasket comes with 4 plastic studs that hold the gasket to engine to keep it aligned then you put pan on. While the FelPro gasket says no RTV is needed I have always used a bead of Permatex Black Ultra along the front & rear curved edge running about 1" onto the flat sides between gasket and engine block and never had a pan gasket leak
Also before you put pan back on use a hammer with pan on flat surface to make sure all the bolt holes are not dimpled in up towards engine. You want the pan rails flat
Old Jun 26, 2019 | 07:24 PM
  #30
Originally Posted by Chimera96
OP
Got it thanks.
I have the pan gasket you mention. Will be cleaning and checking pan very closely.
Acetone or brake cleaner I have used in the past.
Fred's knowledge is well known on this board, as you can see with my join date I have seen a lot of help from him both by simply lurking and directly in posts.
Cheers
