wabro install...1 problem
Old Sep 25, 2005 | 03:55 PM
Showme's Avatar
hey,
Just finished Racetronic Walbro 255 install with plug and play harness.
Everything went great except now my gas hand in way beyond full and I know the car does not have a full tank on gas.
Also...I have one yellow 20 fuse left over from the install.
Can anyone tell me what my problem could be?
-Tim
P.S. You can drill your holes for trap door method a whole lot quicker if you have the drill turning clockwise and not in reverse like I did the whole time except for 3 holes.
Old Sep 25, 2005 | 03:57 PM
SS RRR's Avatar
Re: wabro install...1 problem
Yep... the float for the fuel guage is a bit out of whack.
Old Sep 25, 2005 | 04:00 PM
Showme's Avatar
Thanks,
How long will it take to reset itself and should I fill the car all the way up.
Should I drive the car daily until it does, because normally, I drive the 1-2 times a week.
-Tim
Old Sep 25, 2005 | 04:03 PM
SS RRR's Avatar
It won't reset itself. Mine is still goofy from when I put mine in a year ago.
If you want to try to true it up I'm sure you can fandangle it somehow. I can't be bothered since mine isn't too bad.
Old Sep 25, 2005 | 04:05 PM
Showme's Avatar
Thanks for the info
-Tim
Old Sep 25, 2005 | 04:53 PM
There's nothing to "reset".... its a simple rheostat (variable resistance) and connected directly to the gauge. Sounds like the float may be caught on something, or you didn't reconnect the wire fully. Worst problem would be a faulty sender. The sender is not available as a separate part. You have to buy the entire fuel pump mounting assembly for about $250.
Old Sep 25, 2005 | 04:56 PM
zbomb5610's Avatar
when my fuel pump was put in, the gauge read way above fuel, i mean like more than when i top off. something wasn't plugged in right and then the gauge was reading the usualy above full when i top off but would never go down, the floater was stuck on something, so we did the trap door method and fixed the floater and now everything is fine.
i have the racetronix pump and harness installed.
Old Sep 25, 2005 | 06:33 PM
Showme's Avatar
Thanks,
I'll go back and check the floater and wires again some time next week. The sender was in great working condition before the new pump install.
Take Care,
-Tim
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
