Very Very Frusterated with my car
Old Jan 12, 2011 | 12:06 PM
  #16
kamsvt's Avatar
Re: Very Very Frusterated with my car
Originally Posted by Injuneer
Loss of either the high or low resolution pulse sets a code.
You appear to have a variable voltage on the two signal wires. Odd though that you don't have anything on the 631/red wire. That's the 12V power supply to the Opti optical module. It wouldn't be putting out a variable voltage on the 430/purple-white or the 453/red-black if it wasn't getting 12V from the red wire.
632/pink-black is the ground, so "0" on that wire is normal.
thanks for reply as i remember last night it was o volts on the other two i will check again tonight to verify definitly doesnt make sense not to have power going in but coming out also i have paper clips between the 2 pigtails and thats how im getting my reading so may not b 100% acurate but ill check again
Old Jan 12, 2011 | 06:33 PM
  #17
kamsvt's Avatar
alright so with key on red wire 631 has 12vdc, when cranking i get low voltage from both b 430, and a 453 (also the car fired up when i got home and while testing tried to fire then i unplugged inj. fuse.) i rechecked the white wire b 423 going to icm unplugged while cranking and 0vac. dont know what to do next?
Old Jan 12, 2011 | 10:08 PM
  #18
Godly96_SS_Here's Avatar
So the problem started after you changed out the plugs and wires?
Honestly this exact same thing happened to me, unless you are 100% positive its not the plugs or wires then recheck them again. I have changed plugs and wires on an LT1 many times and thought I had it down. I came here looking for answers on a issue that I tracked for a couple of months, I finally broke down and took it to a known LT1 mechanic in my area and BAM! One of my plug wires had a tiny crack that couldn't be seen arcing or felt, I felt so stupid when he called me and told me he replaced 1 wire and it runs like a champ.
Seriously check out the easy things first, I made big mistakes and one then just kept taking me to the next.
O and by the way, mine started happening about a week after I changed the plugs and wires making it worse as to no thought for being something I did.
Old Jan 20, 2011 | 08:22 PM
  #19
fincsher's Avatar
Do you need an extra hand to fix it? I am willing to help you.
Old Jan 23, 2011 | 01:57 PM
  #20
kamsvt's Avatar
just wanted to update my progress after hours of aggrivating testing and searching i decided to replace the opti spark it fired right up and has continued to do far and ive put about 40 miles on it so far so thanks for all the input
Old Jan 23, 2011 | 03:12 PM
  #21
Let's hope it stays going strong!
Old Jan 23, 2011 | 03:18 PM
  #22
In another thread, he indicates he bought a Cardone Opti. Hopefully, it lasts.
Old Jan 26, 2011 | 07:36 PM
  #23
kamsvt's Avatar
yeah unfortunatly i work at a gm dealer and the cheapest i can get a delco for is 380 and my wife shut me down becouse i had this car for a week and was already dumping money into it ontop of the money i paid for it i would of loved to of got a good one but the cardone was in the budget so if it bites me in the a$$ then ill take it on the chin but it wasnt that bad of a swap hopefully in a year or so i can upgrade to a ls1 pcm and coil packs(efi connection) but anyway thanks for everyones help and special thanks to shoebox your site is awesome very helpful
Jazsun
Dec 29, 2014 12:14 PM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
USAirman93
Nov 24, 2014 03:37 PM
