very desperate, out of ideas. PLEASE!!!
Old Mar 11, 2003 | 07:43 AM
  #31
cndctrdj's Avatar
good luck i hope its a cheap fix
Old Apr 22, 2003 | 07:31 PM
  #32
rickyzZ28's Avatar
Didi you ever figure out what was wrong with your car then. Please post and let us know.
Old May 7, 2003 | 04:19 PM
  #33
phancom's Avatar
well, heres an update:
i changed the opti. i could tell that it cleared my misfire and helped some but the same problem is still there. my last guess are fuel. i dunno if it would be the injectors, reg, or pump. i checked the reg as someone suggested and its NOT dumping fuel into the intake through the vacuum line. i dunno if this would conclude the reg is working fine or not.
sometimes it starts funny and will take longer or will feel like bogged down when just started. i have an oil leak that might be from the back of the intake but i dont think that would be the problem. im gonna get it up this weekend and see where it is coming from. this is a royal PITA but im learning a ton about my car that i would never have learned.
can anyone add anything?
Old May 7, 2003 | 06:11 PM
  #34
phancom's Avatar
how can i check for that?
Old May 7, 2003 | 07:09 PM
  #35
phancom's Avatar
now that i think of it, after i did the seafoam, i did notice an increase in torque at 45mph and higher. hmmm. that would lean me towards injectors but im still unsure. that and the starting issue.
Old May 8, 2003 | 04:23 AM
  #36
phancom's Avatar
TTT
Old May 8, 2003 | 02:20 PM
  #37
phancom's Avatar
ttt
Old May 11, 2003 | 05:13 PM
  #38
phancom's Avatar
i took the car out for a little diagnostic drive on the highway. it feels like it is going to completely max out at 110. i also thought that maybe it could be the egr valve but would it really cause this much trouble? i also thought knock sensor but im not sure. i still think its fuel related because of the occasional start up issue. is there any way i could narrow it down more?
Old May 12, 2003 | 10:16 AM
  #39
phancom's Avatar
boy, you guys must be as stumped as i am. lol
Old May 12, 2003 | 10:52 AM
  #40
TechCam97's Avatar
Originally posted by phancom
i would assume if it doesnt throw any codes than this is working properly. no codes being thrown.
Don't rely on the cars computer to tell you what's wrong. I have a 93 LT1 as well and I NEVER get codes, lol. And I know stuff is wrong. I have a gutted catalytic converter and I've never tripped my SES light. Check EVERYTHING. Just go on down the list and don't stop. It's also a good idea to check your Catalytic converter. In my automotive class we had a 94 Trans Am that had similar problems. He couldn't accelerate very fast, his RPMs acted funny, lost a crap load in gas mileage. We tried everything and he never fixed it and he just gave up and left. The next week he wanted to gut his cat to make his exhaust sound better and once we did that it fixed everything right up. All the honeycomb on the inside was pitch black and looked almost burnt.
Old May 12, 2003 | 11:09 AM
  #41
phancom's Avatar
thanks for the reply.
these 93's sure are stubborn with codes, lol. im trying to go right down the line. there really isnt any other way to check the cat other than cutting it from the pipe huh? when you gutted it, did you just weld up another piece of pipe to replace empty spot?
thanks again
Old May 12, 2003 | 11:18 AM
  #42
TechCam97's Avatar
No, there are no welds required if you just want to gut it. Look under your car at the cat and at the rear of the cat there are 4 bolts. Just unbolt them and push the Intermediate pipe out of the way and you can see inside your cat. Look inside with a flashlight and you'll see all that honeycomb filler.
Old May 12, 2003 | 11:38 AM
  #43
TechCam97's Avatar
If you are interested in gutting your cat, you're going to need a few things.
- 2 foot prybar (The one I used was 3/4 in thick and 2 ft long)
- Hammer
- Misc. sized wrenches
First Unbolt the four bolts on the rear side of the cat and push the I-Pipe out of the way. Then place your prybar on the honeycomb filler and just hit the living crap out of it w/ the hammer. Keep wallowing out the honeycomb until you can hear a lot of crunching then get in the car, start it and gas it a bit to shoot out the broken up pieces. Make sure you don't let it run for long, it may get hot. Then go back and look w/ a flashlight and locate where to break it up next. Keep doing this until you can't see a single piece left inside. Then just bolt her back together and there ya go. All done.
Old May 12, 2003 | 12:02 PM
  #44
faded93bird's Avatar
if your fuel system is good and in the clear start checking the delivery system
plugs and wires if not already done
MAP only thing that gives your car a direct reading to run off if falty car runs like butthole
TPS could be off giving a false reading and cauesing the ramdom idle
didnt see a mention of either of these
ps if your cat is cloged there is something else wrong most likely fuel dilivery
Kempster
Jul 7, 2020 11:00 AM
walt355
Mar 16, 2016 09:35 AM
asilomar244
Jul 12, 2015 05:53 AM
jj_burchiel
Mar 5, 2015 07:05 AM
grohl12
Feb 9, 2003 01:40 AM
