very desperate, out of ideas. PLEASE!!!
Old Mar 8, 2003 | 10:44 PM
  #16
phancom's Avatar
Originally posted by Larnach
catalytic convertor?
had the shop check that, they said it was fine. since then, i managed to bang it off a pothole but i really havent noticed anything different since i hit it. no rattles or anything.
car only has 65k miles too.
Old Mar 8, 2003 | 10:45 PM
  #17
Originally posted by phancom
i would assume if it doesnt throw any codes than this is working properly. no codes being thrown.
Not true. It could be acting lazy or it's gasket leaking and that would not throw a code. Bottom line is to quit guessing and throwing parts at it and get it on a scanner to really find out what the problem is. The computer can tell you most everything that is going on. You need to make use of this resource.
Old Mar 8, 2003 | 10:59 PM
  #18
phancom's Avatar
i thought i made it clear but i guess not. my bad.
i had it on a scanner and it did not throw any codes.
Old Mar 8, 2003 | 11:02 PM
  #19
Using a scan tool to look for codes is only one part of it's usefulness. The other is to use it to monitor sensor function so suspected trouble points can be located.
Old Mar 8, 2003 | 11:03 PM
  #20
JSK333's Avatar
I would check the fuel pressure while running, and also about 15-30 minutes after shutting it off--should be around 40-43psi.
Make sure it isn't bleeding down after shutoff. If it is, you may have leaky injectors and/or a failing fuel pump.
Sounds like when my fuel pump went out. Not fun.
Old Mar 8, 2003 | 11:19 PM
  #21
TMDZ28's Avatar
maybe oil leak to sparkplugs?? i think mine is kinda does the same thing, i saw a leak in the plug wire #1....i'll change that, and keep you in touch
Old Mar 9, 2003 | 12:06 AM
  #22
JustAnotherGuy's Avatar
Im no expert AT ALL but could a bad MAF screw up the Gas mileage??
Please Correct me if im wrong
Old Mar 9, 2003 | 09:29 AM
  #23
phancom's Avatar
it probably could but i have a 93 so its speed density.
anyone else have any ideas?
i really appreciate the help.
Old Mar 9, 2003 | 09:45 AM
  #24
joeSS97's Avatar
Put a vacuum gauge on it .It should have a good steady vac at idle.Maybe intake gasket?
Old Mar 9, 2003 | 01:53 PM
  #25
Z95m6's Avatar
It can't be a intake elbow problem either like suggested earlier since it is a 93 car.
Old Mar 9, 2003 | 03:42 PM
  #26
phancom's Avatar
thats the same thing i was thinking.
Old Mar 9, 2003 | 08:32 PM
  #27
phancom's Avatar
last call.
thanks again guys.
Old Mar 9, 2003 | 09:00 PM
  #28
JSK333's Avatar
Did you do what I suggested concerning the fuel pressure?
Old Mar 9, 2003 | 09:16 PM
  #29
phancom's Avatar
i dont have access to a pressure checker so im gonna check everything else first. if those dont fix it then ill take it to the shop for them to check it.
Old Mar 9, 2003 | 09:31 PM
  #30
97z28/m6's Avatar
make sure they drive it with the gauge hooked up.
