Verdict? (Headbytes porting SCAM)
Old Mar 31, 2013 | 07:45 AM
  #46
TedH's Avatar
re: Verdict? (Headbytes porting SCAM)
Please take personal crap away from this board as it serves no purpose except to ruin the discussion.
Old Apr 1, 2013 | 02:09 PM
  #47
redline9570's Avatar
Posted 2 new videos today, the heads are looking really nice.
Old Apr 1, 2013 | 02:50 PM
  #48
Chet1185's Avatar
I'm just enjoying watching the videos. I love everything about these cars.
Posted from Camaroz28.com App for Android
Old Apr 1, 2013 | 09:06 PM
  #49
Lot of good information in there if you plan to port your own heads also what to look for if you source it out.
Old Apr 1, 2013 | 11:19 PM
  #50
sbs's Avatar
sbs
Originally Posted by redline9570
If I was racing Nascar, NHRA or Indy I would look at flow rates but for what I am going to use the car for; a weekend cruiser and once or twice at the track a year I can care less.
Originally Posted by PWR SHFT
How do/did you substantiate this claim?
300cfm @ 28"
Old Apr 2, 2013 | 06:37 AM
  #51
Originally Posted by sbs
We probably didn't hit the 300cfm mark since I stayed with the factory 1.94 valves but we did get 56.6 on the combustion chambers 197cc runner volume.
The most valve we could of squeezed in there would of been a 1.97 or maybe even a 2.00 but I did not want to add expense to the project and with 197cc with a 1.94 intake valve the math says it is almost a perfect rate of de-compression from flange to valve margin. I can also squeeze more ponies out of it using a different head gasket for better quenching.
I might have them flow bench tested just out of curiosity but like I said for my purpose I really don't care.
Old Apr 2, 2013 | 08:25 AM
  #52
adam85's Avatar
I wonder what the other big porters like AI and LE think of these. I am really suprised this thread hasn't gotten more replies. Are the heads he is doing yours in the vids?
Old Apr 2, 2013 | 08:39 AM
  #53
Yes, these are my head 647 castings I believe but 197cc with stock castings! Did the virtual dyno and came up with 508hp -80hp for drive train loss that put it at 428rwhp @ 6000rpm. On the dyno it probably wont hit those numbers since there is a couple other mods still on the table but 410rwhp is what I am going for now with current mods. Couple things I would of done different one, go with 1 3/4 headers versus the 1 5/8 two, cam choice, since it will be some time before I add NOS I could of went with a 110-112 lsa for now and really hit that 450rwhp mark. But in the long run the current cam will be better for NOS.
http://www.wallaceracing.com/Calculators.htm
Old Apr 5, 2013 | 06:11 PM
  #54
As much as I hate to have done it I ended up changing the cam to a Howard Cams 290-290 237-237 .560/.560 110lsa 106 Hyd. The machinist said this will be the best off the shelf choice. The cam specs are with 1.5 rockers but I got 1.6s sitting here. Ditching the NOS setup with this cam for now.
Old Apr 5, 2013 | 10:21 PM
  #55
RamAir95TA's Avatar
Awful choice. There's a reason you rarely, if ever, see an LT1 build with a single pattern cam. Unless you have a ridiculously killer exhaust flow a single pattern is not ideal. Even LS1s use dual pattern grinds and their heads are light years ahead of ours. And why is your MACHINIST suggesting a cam?
Again, you need to rethink your strategy. But if not, good luck.
Old Apr 6, 2013 | 07:52 AM
  #56
The exhaust ports have been opened up and fully ported and I guess he feels they will flow. Although my headers are 1 5/8 flange opening I still can upgrade them later for even more flow, but what comes out isn't in relation to what goes in? He was pretty adamant about it even though I was looking at the same cam profile that was split duration.
Old Apr 6, 2013 | 08:50 AM
  #57
RamAir95TA's Avatar
I would not bank my cam choice (or my entire build) on a hunch.
Do a search for LT1 single pattern cams. Report back with your findings.
Old Apr 6, 2013 | 09:44 AM
  #58
This is what I came up with from Isky;
Tech Tip - 2003
Longer Exhaust Duration: Is this really necessary?
Most stock camshafts from American production V8, V6 and 4 cylinder engines manufactured today are ground with the longer exhaust lobe duration. Or, another way of looking at this is that they are ground with shorter intake durations! The former embraces the viewpoint that either the Exhaust Ports or Exhaust Pipe system is somewhat restrictive, and is in need of an assist. The latter suggests that the intake system is rather efficient and cam timing can be trimmed back a bit with out much sacrifice in power, in order to maximize throttle response and cruising efficiency.
Take your pick here. There is no absolutely correct viewpoint - because both are probably true! In a stock engine running at conservative RPM levels, for the sake of overall efficiency, fuel economy and a quiet smooth running engine, this staggering of intake and exhaust duration is quite common and appropriate.
However, High Performance is another thing entirely. Change one factor, let's say in this case, the exhaust system (installing headers and larger pipes) and you have just negated in most cases, the need for that longer exhaust lobe. Now couple this change with a different intake system and camshaft and you have really scrambled the equation. But, wait just a moment. Why is it that so many people (racers & cam grinders alike) insist on running a cam with longer exhaust duration regardless of what equipment is employed? The answer is "habit". Most of them have been somewhat successful in doing it their way and will probably never change unless virtually forced by circumstances to do so.
Before we go any further however let's review what it actually is we are trying to do with an engine when we attempt to make more power. Our best result comes when we are cognizant of the fact that an engine is basically an air pump. We pump it in and out (although in a different form) and we have problems when one side or the other is restricted. Balance or the equilibrium or flow should be our objective, unless of course we are not trying to make more horsepower!
Example #1 (Oval track racing) Here, I have often observed that the most experienced drivers are those who are most likely to run a single pattern (equal on intake and exhaust duration) cam. Why? Because such cams always, I repeat always make more torque! These veterans have a more educated foot and greater experience in feathering the throttle in the corners. They can therefore, utilize the benefit of added torque, in the lower to mid RPM range, to their advantage.
Their counterparts, the younger drivers on the circuit, generally are not as experienced and may at times actually get "crossed up" in the corners especially with a lighter car or when they are learning the ropes. In their case, a longer exhaust duration is often the more appropriate choice. It will often help them to drive better, more "flat footed" if you will, without consequence. But please for the sake of accuracy, let us be truthful. The benefit comes from an actual bleeding off of low to mid range torque, which is always what happens when Exh. Duration is lengthened, not from any improvement. The improvement, (if any) would come because of an improvement in scavenging at the extreme upper end of the power curve and would usually be marginal at best. Yet the so-called "extra power" potential of a longer Exh. Duration cam is most often why they are touted - power most people are backing away from at the end of the strait away!
Example #2 (Drag Racing) At the drag strip it's a little different and I feel more honest. Here, racers have long enjoyed longer exhaust and longer durations across the board (If I may add specifically for the purpose of "killing" low-end torque) to keep the tires from too easily breaking lose. This has been successful and sometimes actually results in a slight increase in top end power - something you can actually use in drag racing since it is a full throttle endeavor through the lights. Keep in mind here though, it's quite possible that a longer duration cam overall would have done just as well or better. In other words if you needed that longer exhaust for top end, perhaps the intake could have benefited from such a lengthening as well.
One of my favorite expressions is how "The Drag Racing mentality has infiltrated the ranks of Oval Track". Many have crossed over and made the switch in the past 10-15 years and some have brought their preconceived notions about how to cam an engine with them. A few may actually read these concepts and if they do so will at least come away with a better understanding of what they are doing. On the other hand they also could find that this information might actually help their cars to run just a bit faster!
Note: Readers may find Camfather Ed Iskenderian's Top Tuners Tip #33 "Can an Exhaust System Over-Scavenge the Combustion Chambers" to be a relevant precursor.
From: ISKY Racing Cams - Do It Right. Race with the Legend. Camshafts, Connecting Rods, Valve Springs, Lifters
Old Apr 6, 2013 | 09:51 AM
  #59
Tech Tip - 2004
Intake Restriction and Over Scavenging: "Waste not...Want not!"
It is certainly an over simplification to make the statement "that which is not wasted, should be inducted". However, in the case of restricted intake systems and in particular 2-BBL carb rules, it is not far off the mark. Engines with such restrictions are "choked off" to the point where they will not run much past 6500 RPM (if even that high) without dropping off sharply in power. You might have trouble running very fast yourself if someone had your windpipe choked down to say 50 or 60% of it's normal capacity. Under such conditions, would you volunteer to give blood at the Red Cross? Of course not, but without knowing so, racers often do the equivalent with their engines by running a camshaft better suited for a 4-BBL class! How So?
If you'll recall in last months tech tip: "Longer Exhaust Duration: Is This Really Necessary?" I discussed how, through habit, many racers and cam grinders alike are predisposed to running camshafts with longer exhaust durations, whether they need to or not! Well, in the case of restricted intake applications, if there was ever a situation in which you'd want to avoid the longer exhaust "trap" it's here! Especially the 8, 10, 12 or even longer degree spreads, I often discover people employing.
Use such a cam at you own risk - and don't be surprised to find that your exhaust temperatures are unusually high. Your headers in fact may even glow cherry red. There is a very good reason for this. Raw (unburned) fuel is burning "late" or in the pipe (header/manifold). You may have a good equilibrium of flow going here but there is just one problem. Much of what should be inducted into the cylinder is being scavenged out the exhaust! You see, although back pressure in an exhaust system can be restrictive, the only thing that could be even worse is a reduction of it to the point where you are now, in effect pulling a vacuum. In the case of an intake restriction, very slight back pressure is preferable to avoid "over scavenging".
Yes, Yes I know. You are probably thinking "what's wrong with a little scavenging?". Well, nothing if you can afford it. But with intake restrictions (either small 2-BBL carbs and/or restrictor plates) you must be very careful. You already have reduced intake potential and therefore simply cannot be cavalier about valve overlap and scavenging or you'll be way down on power and have those nice bright cherry red pipes to show for it! Case in Point: One racer who called me was in this exact situation and was running, not surprisingly, a 14 Degree longer exhaust duration. It was Friday afternoon and he needed a cam the next day for the last "points race" of the season and UPS had already picked up at Isky. "Too Bad" I said, "You don't have a set of those low ratio break-in rocker arms because they could really help in this case". " I do have some" he said "but they are only 1.2:1 ratio - is that okay?" I told him to use them (on his exhaust valves only of course) and he finished the race 2nd having come from the back of the pack. Later we made him the right cam so he could avoid this make shift approach.
Unfortunately, the symptoms are not always as obvious as in this case to allow for a speedy diagnosis. Also, it's not only longer exhaust duration that causes the problem. Although it is usually the primary offender, it is often coupled with too close a lobe separation angle of say 104 Degrees. A widening to 106 Degrees or preferably 108 Degrees (some go even wider) is usually prudent.
I am not absolutely dead set against a slightly longer exhaust duration in these cases as a 2-4 Degree longer exhaust lobe is permissible under some circumstances (if your running a completely stock exhaust system including mufflers for example). Each case is different, depending upon the equipment employed. I might even recommend shorter exhaust duration to some; if I feel they have "overdone" their exhaust ports and or exhaust system a bit. What matters is the end result and if you're out of balance on one side simply employ what I call the "Great Law of Compensation" to bring you back to that equilibrium of flow.
So, how can you tell if you may need to make some of these changes in your camshaft? Well, short of trying a lower exhaust rocker arm ratio, you can increase exhaust valve lash .004" - .008" temporarily to see if there is any improvement. You can also try and increase restriction (smaller headers or pipes, or in the case of open headers a longer collector) and simply observe the results. Remember, "One test is worth a thousand expert opinions". Keep this old axiom in your "tool box" and you'll be ahead of the game. How do you think Smokey's shop got to be "The best Damn Garage in Town" anyway? Yes, he had those country smarts, but his experiences in racing and his willingness to test are legendary!
Old Apr 6, 2013 | 11:24 AM
  #60
For those of you watching the videos, I posted two new ones today, enjoy.
