vehicle problems
Old Jul 24, 2006 | 09:14 PM
Daniel6718's Avatar
vehicle problems
move this where it needs to be...just got a car back together that was in alot of pieces...i put the motor tranny clutch wire harness computer rear end in this car
problem is that i got everything in. I think everything is right but im not sure...problem is when i turn the key on only the low trac, brake, seat belts and air bag lights come on...no service engine light no check gauges ect. the car will not turn over and desotne even click at all...the voltage gauge also does not move when i turn the key foroward...does anyone have any ideals...lights radio fog lights interrior brake turn signals all work..anyone kno whats unhooked? what is wrong
thanks
daniel
Old Jul 24, 2006 | 10:03 PM
davidarel's Avatar
Re: vehicle problems
Do you have a shop manual with the ecm pinouts? You need to check the ingnition and bat wires and make sure the computer has power on all circuits. Also, make sure ALL the grounds are connected and secured.
Old Jul 24, 2006 | 10:58 PM
philcam01's Avatar
thanks
daniel
are the three plugs under the pass kick panel pluged in??? They are blue, white, and black in color. These three plugs will make these not work, starter, alt, and no PCM sync. I would start here and get back and let us know.
Old Jul 25, 2006 | 12:58 AM
Daniel6718's Avatar
yes the wire harness was completely out...i stuck the harness through the firewall and connected the 4 connectors that came through...i guess if some can go to shoebox site i could see if the pcm is gettin voltage... i think the fuel pump isnt commming on either...its as if the acc switch isnt working...bc it turns nothing on...
Old Jul 25, 2006 | 03:58 PM
Daniel6718's Avatar
sorry guys there is a ground from the driver frame rail i forgot to connect to the motor...problem fixed...goana start once i get new fuel rails
DirtyDaveW
Dec 1, 2016 05:37 PM
eanhl2004
Apr 4, 2015 12:01 PM
Apr 3, 2015 10:54 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
chevysam
Jan 16, 2015 07:45 PM
