Vats Problem or not!!!!!!
Old Feb 5, 2011 | 07:34 AM
gld77's Avatar
Im not getting any good answers for my problem it like going in circles someone has to know what going on here with issue.Again 97z engine in my94z.starts runs for a second then shuts off.I can hear the fuel pumpas normal.Now it seems the key is fine right so that would eliminate the resistance issue or what.I know that what ever it is its something simple.
Old Feb 5, 2011 | 08:46 AM
Re: Vats Problem or not!!!!!!
Been answered. Scan for a DTC 46. It does not turn on the SES light.
https://www.camaroz28.com/forums/sho...30&postcount=4
You have at least 3 threads on this forum for the same problem. That might not be helping, either.
Old Feb 5, 2011 | 10:14 AM
This is getting out of hand. You have a mixed combination of a 94 chassis, a 95 PCM and a 97 engine. And you are upset because no one seems to be able to give you an instantaneous response on why your engine will not keep running after it starts.
Several of us have tried to help you, but the effort is being diluted because you have scatter-gunned your posts all over the site. In one post you said you had a 98z engine. In another, you posted a reply to a question, but appears you hit "new thread" instead of "reply", and started yet another thread.
I'm going to try and move all your posts into a single thread (MERGE), so people can see all the responses we have made trying to help you, and all the responses you have made trying to answer us. When you scatter things through multiple threads, you really hurt your chances of getting help.
In less than 24 hours, you posted:
https://www.camaroz28.com/forums/sho...d.php?t=795922
https://www.camaroz28.com/forums/sho...d.php?t=795970
https://www.camaroz28.com/forums/sho...d.php?t=515742
https://www.camaroz28.com/forums/sho...d.php?t=795972
Old Feb 5, 2011 | 10:26 AM
OK.... now they all lead to the same thread, so we can close this one. You might want to go through the new "merged" thread and delete the posts that are duplicates, or no longer make any sense. That thread will be located on the "General 67-02 F-Body Tech" forum.
Heathen1
Jan 2, 2016 04:27 PM
Klypto
Mar 9, 2015 04:25 PM
Noer
Feb 28, 2015 11:29 AM
Lakebratt
Feb 5, 2015 07:55 PM
Fedesna
Nov 23, 2014 11:06 AM
