Valvetrain setups for GM847 or CC306?
Old Mar 29, 2008 | 09:04 PM
  #16
dangalla's Avatar
i am far from a professional on this subject, i learn from the guys here every day
but i would use the pac 1518 springs and the ls7 lifters, you def need to get the springs now, you could use your lifters as long as there is nothing wrong with them. i would also get new rockers which also raises a few questions - 3/8 or 7/16 and self aligning or non self alinging. you could get by with 3/8 and SA rockers, but if you have the money it would be a good idea to upgrade to the 7/16 NSA which would also require you to purchase 7/16 studs and guidplates with chromolly pushrods. you "should" upgrade the pushrods to chromolly for added insurance anyway and the trick flow can be had for a decent price
Old Mar 29, 2008 | 09:05 PM
  #17
97SS0594's Avatar
im using comp R lifters, 918 behive springs, comp NSA 1.6RR and the comp hardened pushrods with my GM847 cam.
Old Mar 29, 2008 | 09:58 PM
  #18
MadMike 97 Z28's Avatar
so if i get the pac 1518s and my stock lifters are in good shape i could reuse them with those springs? also when i send my heads off to the shop what should i get done should i get them to set them up for guide plates and keep in mind im trying to do all this on a small budget so i can't spend a ton of money on headwork.
Old Apr 5, 2008 | 05:06 PM
  #19
ssean92's Avatar
the ls7 lifters wre oiling fine just couldnt get them to seal with the pushrod???? that was priming it, turning the engine, tried evenrthing, actually thing I was mis diagnosing it, I should have let it run alittle longer, just was scared to trash engine. But anyways I took them out and put oem replacements in, I think I was hearing the header leak and mistook it for valves...... anyways good luck
Old Sep 4, 2008 | 02:00 PM
  #20
Connexion2005's Avatar
Originally Posted by fireman
CC306, Comp 986 springs, Comp Type R lifters, GMPP 1.6 rockers, stock pushrods.
Been running this setup for 5 years now, makes peak power at 6200rpm with stock heads.
I'm impressed this setup worked well for you. Those GMPP rockers are "maxed" at .575 lift and the exhaust side on a cc306 cam is a .576. I'm running the same cam with those rockers and was worried but a post like that makes me feel alot better. Anyone else running the GMPP rockers with a cam around .575 lift?
Old Sep 4, 2008 | 03:33 PM
  #21
Rising Phoenix's Avatar
1.6 Comp ProMag NSA rockers and hardened guideplates, 918s (the "updated" ones) with +.050 steel retainers, 7.200" (stock length) chromoly pushrods, LS7 lifters. Geometry check showed good even contact with the valvestems. Revs out to 6600rpm without problems!
Old Sep 4, 2008 | 05:24 PM
  #22
wow old thread. i ended up running the parts shown here and reused stock lifters.
http://www.youtube.com/watch?v=pBJupT81Sh8
Old Sep 5, 2008 | 12:48 PM
  #23
Jlo's Avatar
Jlo
is that.. on the stock short block??
Old Sep 5, 2008 | 12:54 PM
  #24
yes, but shortly after the install it started showing signs of bearing failure so its coming out and im building a 355 with some forged internals.
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
FryedClutch
Sep 1, 2015 08:24 AM
detroitmuscle
Jul 31, 2015 04:21 AM
