Which valvetrain setup
Old Feb 24, 2006 | 12:17 AM
  #16
CamaroGuy22's Avatar
Re: Which valvetrain setup
Originally Posted by turbo_Z
Why do you want to go with the XE 224/230 when there are so many other options out there?
The 918 beehives are supposed to be good springs and can handle much more abuse than the 224/230 can give them.
On a daily driver setup what better options are there?
Old Feb 24, 2006 | 12:18 AM
  #17
What are the limits in ability of the SA Comp Pro Magnum Roller Rockers Handle? Is it also true you need machine work for NSA roller rockers to work?
Old Feb 24, 2006 | 12:48 AM
  #18
1racerdude's Avatar
No machine work for the NSA's but ya do need GM guideplates and hardened pushrods.
A '94 should have hardened pushrods if it's stock.
Ya don't need 7/16 studs with the beehives unless that's what fit the rockers.
The Pro Mags will handle a hell of a lot more than you are fixing to give them.
Old Feb 24, 2006 | 12:57 AM
  #19
So with the XE 224/230 cam the 1.6 Self Aligning Pro Magnum Roller Rockers will be more then fine? That is what I currently have, they are not installed, after reading alot of posts people act like they are not worth a crap and to get NSA.
Old Feb 24, 2006 | 01:17 AM
  #20
1racerdude's Avatar
I won't say they are no good, they shouldn't be run with a performance cam IMO.
There are some that run them but I haven't got that brave yet. 40 years of using RR with guide plates or shaft rockers spoil's one as to not having any problems.
Old Feb 24, 2006 | 07:08 AM
  #21
Demon's Camaro's Avatar
In the prices I listed Im getting basically complete kits for that. So even though I have hardened pushrods Im getting another set. Since comp pro mags are like 240-300 depending on where you get them the package deal is pretty sweet. Basically for the valvetrain all I need now is to get a cam and that will be done. phewwwww.
Now on to the complete fuel system, complete drivetrain, timing conversion, body restoration, and slicks.
Old Feb 24, 2006 | 10:20 AM
  #22
WS6T3RROR's Avatar
if you're using beehives you're gonna have to ditch the SA rockers. because if you get a proper installed height (+.050 locks) there aint gonna be enough valve stickin up out of the retainer for them to stay on and if a rocker jumps off and gets bound with another one you're gonna have some pieces to replace.
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
FryedClutch
Sep 1, 2015 08:24 AM
detroitmuscle
Jul 31, 2015 04:21 AM
